Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
  • Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
    https://www.parts-express.com/dayton...-dsp--300-8010
    Just in stock.... Incredible flexibility for under $200.
    Will be available at the Midwest Audio Fest!
    Oh sweet Moses! Just read thru the pdf. If this was available a couple of months ago, I'd have snatched it instead of the inuke!
      Beautiful! Now add to the product line a 2ch and 3ch unit that work up to 20kHz for 2 and 3-way speakers and we'll laughing!
        Looks like it actuallg has some useful dsp unlike the bigger dsp plate amps 1200dsp and 2400dsp.
        https://www.youtube.com/channel/UCm2...oSKdB448TTVEnQ
          What's not useful about the SPA1200DSP or SPA2400DSP? This product as well as the higher power versions both have 5 band PEQ with limiters...what am I missing?
            I believe this offering is in response to our criticism of the series of plate amps that came out a while ago with very unflexible fixed x-over settings.
            Good job PE!
              This is definitely a step in the right direction. A 2 and 3 channel version would be really great, and I bet really popular.
              Documentation says 7 bands of PEQ, I only see 5. Am I missing something? More/steeper cutoff slopes would be nice, too.
                Yeah, I need to clarify that a little.
                The PC interface has a 5 band parametric EQ...
                There is also a seperate 2 band EQ accessible through the LCD display on the amp itself. It's more for making adjustments on the fly. You can even save 3 presets that you can set for specific situations (music, movie, party... For example).
                  Cool! This is one I will consider buying. It has enough features and flexibility to be useful to me. And the price is right.
                    Just noticed that the warranty is 5 years!? Even better. When did the warranty for electronics become this extended? Did I miss something?
                      Thats a nice option to have for a single sub . 2 channels would be a huge improvement. I like the inuke but the lighting and color is not ideal for my setup. I think most people use 2 subs here or need 2 channels for active woofers for left/right channel. I have two 8" HF subs im running off of a carver 2ch amp and straight out of my reciever and its pretty nice so far.
                      My Build Thread's
                      Carrera's / Finalist TL's / Speedster TMM's / Speedster MTM Center / Overnight Sensation Surrounds
                        1. Is there anyway to set the subsonic filter below 25hz?
                        2. Why don't you have more plate amps with subsonic filters below 20hz?
                        3. Will there be a 500-600w version soon?
                          I'd suggest that you can turn off the subsonic filter and use one of the PEQ bands for your low frequency cutoff, as they have a min freq of 10Hz.
                            May I ask you all a question regarding this plate amplifier?
                            I have (almost literally) fallen heir to a very interesting subwoofer (prototype) project, in the form of a large-ish, and very heavy MDF box loaded with a couple of 15 inch, Italian (SICA) DVC subwoofers of -- ahh -- rather robust construction.
                            DSC_8307 by Mark Hardy, on Flickr
                            One is conventionally mounted in the front baffle of the enclosure, the other one (shown above) is mounted so as to fire into the (otherwise sealed) enclosure from the bottom as shown (with the back of the basket hangin' out in the breeze, beneath the subwoofer). The subwoofer encosure sits on a solid MDF base, which is a few inches "below" the bottom mounted woofer (i.e., the one shown in the photo).
                            Here's a "side view" of the bottom woofer in situ.
                            DSC_8309 by Mark Hardy, on Flickr
                            So, the deal here is that the four voice coils can be connected in various series or parallel combinations "for best results". Some of the possible permutations of VC connection could result in a nominal load impedance of 2 ohms (if memory serves).
                            I had been thinking of getting one of the Behringer iNuke DSP amplifiers to begin to experiment with this behemoth -- but then I saw this new PartsExpress ("Dayton Audio" brand) plate amp with DSP and thought, hmm, that might be at least as good of a choice.
                            I mentioned it to the "source" of the subwoofer project, and his response was:
                            "...suggest you go with the Parts Express plate amp. You'll have a great user community available to you..."
                            This was impetus enough for me to (finally) join this forum and ask you all if you knew about the impedance capability of this new amplifier?
                            Thanks for your attention and for any advice/information anyone here could supply.
                              The new amp is capable of a 4ohm load minimum.
