The new MiniDSP 2x4HD has made all my skills obsolete. How about yours?
  • #76
    Originally posted by Kornbread View Post
    Can you do that with a usb input?
    Maybe. Plugging in two devices will likely result in two separate audio devices in your computer, so it may work if you can get your software to output to two audio devices at once. This should be fairly easy in Linux with pulseaudio, however I can't say the same for Windows, but a google search leads me to believe its possible
    • #77
      How do the DSPs know what is right and what is left?
      • #78
        What do you mean? The DSP doesn't need to know - you do ;) Internally on the 2x4HD you have a "matrix switcher" so you can route any single input to any number of outputs at your choice.
        • #79
          I guess I saw that as have both left and right signals going to each of the left and right speaker xovers. Admittedly, this is from the outside looking in. So- you could in theory have a 4-way active DSP xover with FIR filtering via analog outs if you have 2 of the 2x4HD?
          Just trying to learn,
          • #80
            With a toslink splitter you will of course get both left and right channels going to both units. Then in the DSP config you simply route one channel to all 4 outputs, and route the other channel to all 4 outputs in the other unit. Yes, with 2 units you can make a stereo 4-way crossover, the downside being that you will have to load the DSP configuration individually in each unit, which makes the on-the-fly changes a bit more cumbersome, but I have to do the same thing with my Hypex DSP plates. The MiniDSP plates on the other hand are ethernet enabled, so you can plug them into your network and access over the wifi with your laptop. There are USB over ethernet devices, but an extra cost and I can't speak for how well they work in this application.
            With the original 2x4 product, you just have to get the 4-way advanced plugin instead of the 2-way advanced to do the same thing I've described above. The 2x4HD only has one plugin that provides all the features.
            • #81
              My concern was synchronization of timing between the two device clocks. I understand it to be an issue in SoundEasy if using two sound cards. Maybe that's not a concern outside of the PC environment.
              dlr
              Dave's Speaker Pages
              • #82
                I think that timing will not be an issue with two units, but I have no experience of that. Input signal is in sync and processors etc are similar. In theory there might be some difference that can be measured and heard as L/R shifting of stereo image.
                • #83
                  Yes, you can use TWO 2x4HD units via USB Audio.
                  Mac's audio subsystem is capable of using different audio inputs and outputs from multiple devices (sound cards) at the same time with audio applications.
                  So it's not an issue under OSX: https://support.apple.com/en-us/HT202000
                  Under Windows, it can be done, but with a little bit more work. You need to download some additional third party software (device drivers- Jack Audio and ASIO4ALL)
                  There is some latency between the 2 units because they run asynchronously. The latency will be related to the PLL buffer. So it's extremely tiny.
                  You'll want to use one board if you think this is a problem (real or perceived)
                  It's good to have a healthy level of scepticism. But getting too bogged down in all the negatives can stop you from exploring the positives.
                  As I said, anyone with a recent Windows PC can experience DSP based crossovers for themselves without risk or cost with REW, rePhase and Equaliser APO. Why not try it?
                  • #84
                    dlr
                    With SoundEasy you may have issues getting accurate phase response if your measurement is offset by a few samples due to clocking through different soundcards. This is important for aligning drivers on a baffle where 1mm of acoustic offset makes a difference. In a stereo pair, I don't think one speaker being off by a sample or two is going to make any difference at all.
                    • #85
                      I think that the concern is stereo imaging. I believe that the cards discussed on the mail list were those that could be set up to have a common clock between the boards. It would be interesting to hear the experience of anyone who may have tried a pair of these.
                      dlr
                      • #86
                        This setup wouldn't be any different than the setup of using a pair of the miniDSP plate amp or the Hypex equivalent. What I am saying is that the difference of a sample or two due to clocking isn't going to be enough to affect the stereo image in any way. No more than moving one of your speakers by 1-2mm in your room.
                        • #87
                          I use REW, but have no idea about the other stuff. Do you have a write-up on how to use rePhase and EQ APO with REW?
                          • #88
                            Excellent Introduction to REW & miniDSP 2x4HD
                            https://m.youtube.com/watch?v=ihOMKQ3i2OM
                            Covers in-room measurements, integrating a speaker with subwoofers. Similar principles apply for crossover design, read this next:
                            https://www.minidsp.com/applications...-2x4-hd-twoway
                            • #89
                              For using your Windows PC as a audio DSP, Equaliser Audio Processing Object can enable all sound coming of your selected sound device (or BT connected headphones) to be equalised with complex filters.
                              wiki entry:
                              https://sourceforge.net/p/equalizera...Documentation/
                              • #90
                                RePhase tutorial
                                https://www.minidsp.com/applications...phase-fir-tool
                                Same principles apply if you are not using the miniDSP product
