Inductor layout ok?
  • Inductor layout ok?
    I've got a tight space to lay out the crossovers for a boombox build. It will have a small hollow stand and I'd like to mount the crossovers inside it instead of the cabinet. It only has 4 inductors total and I plan on mounting them vertically inside. They will be spaced close due to the amount of room. Two inductors are 20ga air core and the others are tiny 22ga ferrite cores. Does this layout look ok?
    If that's all the space you have, you really can't do any better I don't think.
    Maybe test them with the DATS once you have them in approx. position to see if the ferrite coils are causing any changes in the other inductors.
    TomZ
      Rotating the second coil from the top and the bottom coil 90 degrees would give more space between those and the other two. Coil cross talk is reduced by the square of the distance between them, so every little bit helps.
      www.billfitzmaurice.com
        I thought it was a no-no to be able to 'see' another inductor through the donut hole so to speak?
        TomZ
          Ok, so like this but with a little more space between?
            TomZ
            Tom's rule of thumb is correct.
              That's how I'd do it.
              What's most important is that they're separated as far as possible, secondary to that is that they're not on the same axis. In both cases the coils are 90 degrees off-axis with respect to each other, so I'd go with the one that gives the wider spacing.
                I've got about 6.5 inches to work with if that helps any. I was looking at this diagram below and couldn't decide on what would be best.
                  Your first layout is best.
                    That diagram, specifically the second arrangement, is misleading. I've proven this with measurements for mutual inductance and voltage coupling. If the perimeters, not the centers, of two coils (the wires, not the bobbin) are 2" or more distant from each other, you have no worries, even with all of the inductors laid down on their end caps the same way. That automatically takes into account inductors with different diameters, which those capacitor tests did not. Still, in your case you probably have to orient them as suggested.
                    Paul
                      Thanks for the input guys, it's much appreciated.
