5" Woofers, need help deciding.
  • 5" Woofers, need help deciding.
    Need to decide on a 5" woofer, (and a couple 6.5") to mate with a Vifa XT25TG30-04 Tweeter
    Tangband W704
    HiVi F5
    HiVi M5N
    Faital Pro 5FE120
    Faital Pro 6FE100
    Fountek FW 168
    Deep bass is NOT a requirement, but smooth integration with tweeter, low distortion and clarity are.
    Yes I know quite a diverse set of woofers, but tough to decide not really having heard any in person.
    I'd stay away from metal cones to make sure the midbass has enough top-end FR to meet it at 2.2k+.
    That said- the FE120 or F5 would be very likely success stories, IMO, and my choice would be the F5.
    I know the F6 would also be up to the task should you want a 6.5" as well.
      Why not FW146? The smaller Fountek will allow for easier integration due to the higher breakup. FW168 has a breakup around 7300Hz, so expect a 3rd order distortion peak around 2450Hz, so ideally crossover freq should be below this around 2kHz. The FW146 on the other hand, has breakup around 8800Hz, so the 3rd order peak is pushed up to 2933Hz, making a crossover around 2.5kHz workable. The XT25 has distortion peaking up quickly below 2kHz, so a crossover above 2kHz is probably a good idea.
        Yes- the 146 might work. The M5 has a lower FR peak than it does.
          So are you saying that a fundamental resonance of 8800 hz will cause a 2900 hz resonance ?
          craigk
            I'm saying the 3rd harmonic of 2900Hz will excite the resonance at 8800Hz. You can see for yourself, a peak in 3rd order distortion a full 10dB higher than the rest of the passband.
              The Silver Flute 5" has a very similar breakup, both in shape and magnitude. On the surface, it sounds fine. But man, oh man, does it bring the ear fatigue unless you shut it down early.
              Wolfy, why not the 704? Your comments suggest it gets last place. I thought it was completely unobjectionable (IMHO).
              nothing can stop me now
                I'm saying the 3rd harmonic of 2900Hz will excite the resonance at 8800Hz. You can see for yourself, a peak in 3rd order distortion a full 10dB higher than the rest of the passband. [ATTACH=CONFIG]n1343811[/ATTACH]
                I agree with that direction. Still not sure how audible it would be after crossover is added.
                craigk
                  The 704 will likely have trouble meeting the XT25. I know of one design for certain where they didn't meet in the middle.
                  It's a good driver otherwise.
                    I was under the impression the TB W5-704 extended fairly high, from zaph's measurements it went easily over 4k response wise.
                      It would work great with the XT25
                      craigk
                        What about the RS150P?
                          Yep- that would work too.
                            I have not heard them, but the Faital Pro 5FE120 has some nice flat looking response curves with an extended high end for a woofer and a smooth roll off. Both of which I think are important for good integration with a tweeter, especially if you prefer simple crossovers. The Tang Band W5-704 graph looks nice also.
