'Tandems'- an InDIYana 2018 theme driven build process...
  • #31
    I told you it was difficult!
    • #32
      Sometimes it takes a sledge hammer!!!!
      • #33
        Cool build Ben, the isobaric approach is an interesting variation from the norm. I always enjoy following your build threads and enjoy reading your crossover adjustments and logic through the process.
        Projects:
        transcenD: http://techtalk.parts-express.com/fo...5035-transcend
        Summits: http://techtalk.parts-express.com/sh...75-The-Summits
        References: http://techtalk.parts-express.com/sh...-My-References
        Vintage Style 2-way: http://techtalk.parts-express.com/sh...-vintage-2-way
        • #34
          It will be interesting to see if the 15K dip is real, you might need a few more parts
          John H
          SLS-85, BMR-3L, Mini-TL, BR-2, Titan OB, B452, Udique, Vultus, Latus1, Seriatim, Aperivox,Pencil Tower
          • #35
            Thanks Ben, given the price of the woofers, the XMAX, and the relatively higher sensitivity, ISO makes a lot of sense, not much to loose and plenty of benefits. Thanks for the sims.
            • #36
              Lots of parts.
              • #37
                How many parts you end up with, rpb? I'm guessing you at least notched the woofer bump, but I can tell you did more than that.
                Now- how long did it take you to get there? I'm guessing 3-4 hours at least. I'm guessing I have 5-6 hours in measurements, adapting and simulating for both of the versions I did.
                Anybody else wanna try it? It's difficult, but it is fun!
                John- I doubt I'll fix that unless I don't like what I hear.
                As to FR measurements, I'm planning on driving the mid with say a sine wave at about 20 Hz while I measure the horn. This will hopefully yield an average of cone position for the mid, and see how it affects the horn's response. I know the sine wave will show up in the plot, but likely negligible. I also plan on a one-position method for the mid and horn to get time of flight phase for simulations.
                • #38
                  I spent about 2 hours initially, and had something about like what I posted, but I looked at total phase, and thought something was horribly wrong. I tried to fix it for a while, then decided that it was just the way it was going to be. By that point, I had changed most of the filter, and couldn't remember some of the values. So, after all that, about 3-4 hours. I'll get the part count tonight.
                  28 parts.
                  • #39
                    The dip might be the case of on-axis cancelation, where off axis the dip fills in. wrt the 20 Hz sine wave, the cone shape will have the most impact on the tw FR. At 20 Hz the cone may flex more than realistic. Could use a battery and move the cone to max in or max out positions.
                    John H
                    • #40
                      This would be more fun if the notch would not have been included in the FRDs
                      John H
                      • #41
                        Yes- I thought of doing that as well.
                        • #42
                          More parts..... Guess how many! I'm just having some fun. This x-over would be ridiculously complex, and expensive. I just wanted to play a little. Not very amp friendly either.
                          • #43
                            Yikes! 2 ohms, huh?
                            How about- 36!
                            • #44
                              Yikes! 2 ohms, huh?
                              How about- 36!
                              That's a really good guess. If I counted right, and use the dcr on a coil, or two, I have 37.
                              • #45
                                This is what i got after playing around with it for a few hours, hopefully i set the drivers up correctly
