Finishing MDF
  • #16
    Originally posted by bolland83 View Post
    Mitered corner joints and vinyl wrap, duratex on the baffle, easiest finish job ever. Something to consider for future projects.
    [ATTACH=CONFIG]n1345629[/ATTACH]
    ​That duratex coat looks sweet....!
    Brian Steele
    www.diysubwoofers.org
    • #17
      Thanks! It's pretty amazing stuff, I love it. Super easy to work with, and pretty hard to screw up, even for a hack like me. Their foam rollers are also very nice, I notice they wash off exceptionally well, so they can be re-used quite a bit.
      My modest builds:
      Armadillo TM, A.K.A. Lil' Dillo
      Tarkus/Armadillo build #2
      Armadillo Center Channel
      Au-Rock-O Sub
      Tarkus
      Staining MDF tutorial
      • #18
        Update: i have the cabs sanded to 220. I don't recommend using undiluted glue, or at least in the manner i did, because it making sanding difficult. I was able to get away with one coat but using my ROS and just hand sanding was able to heat and melt the glue in a could areas. It wasnt horrible and i was able to fix them, but i can see using two thinner coats could make this process smoother Sent from my iPhone using Tapatalk Pro
        • #19
          I only use a single thin coat. If you try to put another on it just sits on the top. I guess a second coat could be handy if you missed spots but it isn't too hard to get complete coverage with a single coat without missing spots.
          • #20
            ​Yup, that's been my experience using undiluted glue as well. I use a 50/50 (or even thinner) mix for ply, but MDF does pose a challenge - make it too thin and the MDF just absorbs it and starts swelling.
            Brian Steele
            • #21
              ​I coat until it starts beading on the surface, indicating that the surface is properly sealed. Thinned wood glue cleans up easily with a damp cloth (before it dries), so I just wipe off the excess when that happens.
              Brian Steele
              • #22
                Originally posted by Wolf View Post
                Trigger-caps really he!p! No sore fingers! I use Elmer's white glue straight, no water. Don't sand heavy handed, or the resin will melt and flake if it went on too thick. Use a roller or brush to apply the glue thinly and evenly.
                Do you think I could get away with sponging the stuff on?
                After an awfully long break, I'm trying this "speaker building" thing again, and my first project is already showing MDF seams...
                • #23
                  You could just rub it in with your fingers. I used to do it that way before I started using a brush, and only on the edges. Now I coat the entire cabinet to seal it, but just a coat to get coverage. I don't lay it on thick.
