Legacy audio, new design...interesting
  • Legacy audio, new design...interesting
    http://www.audioxpress.com/news/lega...r-at-rmaf-2017
    Wish I could make it to RMAF to hear this. The amt array has me curious as to how it is implemented. And what drivers these behemoths are using!
    Yeah- odd to me I think. They've not always been a company to go with DIY convention as far as driver arrangements go.
      Interesting that they are nearly fully active save for one amp you need to provide for the tweeters.
          Originally posted by Jeff B. View Post
          "The side passive radiators are dual 12” aluminum diaphragms with 3” dual 4 layer voice coils."
          Hmmmmm..... passive radiators with voice coils. Are they passive or not?
          Yeah, me thinks someone needs to check their add copy.
            Servo? If not a bad editing job....?
              Maybe they're using the voice coils to provide motive force for resistive damping . . .
                Interesting, I will make sure to check them out at RMAF this weekend. They may be doing a similar idea of what I plan on doing on my speakers of artificially adding a slightly delayed version of the signal in order to achieve a level of spaciousness normally only achieved by well designed dipole speakers without having the problems of dipoles.
                  Dang, those look freakin sweet. I heard the Aeris speakers, and own a brand new set of Legacy Calibres. I can only imagine how utterly awesome those might sound. They always go for piston area to minimize excursion and thus distortion in already low-distortion drivers. Eigh-Emm-Tee is for me!
                  Here is a link to their Blog: http://legacyaudio.com/backstage/blo...-at-rmaf-2017/
                  Where the hell is the 1.5" Midrange driver???
                    Maybe it's between the tweeters.
                    Ron
                    C-Note Iron Driver Build
                    The Lydias
                    The Cherry π's
                    The Champs - Iron Driver 2015 Entry
                    My Projects Page
                    The good thing about science is that it's true whether or not you believe in it. - Neil deGrasse Tyson
                    http://www.youtube.com/watch?v=cjuGCJJUGsg
                      Looks like horn loaded AMTs and mid dome.
                      Kenny
                      http://www.diy-ny.com/
                        An earlier attempt of a similar concept by the good, old Acoustic Research. https://www.stereophile.com/content/...-1-loudspeaker
                          Boy the similarity to the Acoustic Research work is striking.
                          And then I think back to technologies like Carver's Sonic Holography and wonder if people actually think these technologies are better, or just different.
                          I get they sound remarkably different. And I don't doubt that on some recordings they might sound remarkably better.
                          I just cannot fathom that the characteristics imparted equally improve the listening experience of all material.
                            Not horn loaded, but a clever solution to what would otherwise be a limited directivity AMT.
                            I'm not convinced on the mid dome. There's not enough resolution in the image to tell, but it kind of just looks like a wire frame holding the AMT's in place, that you can see through to the dust cap of the woofer behind.
                            The wavelet DSP to me sounds like a confusing description of FIR filtering.
                              [ATTACH=CONFIG]n1347985[/ATTACH]
                              Ron
                              I thought so too, until I looked at the high resolution image from the Legacy webpage that I linked. It almost looks like its just the dustcap of the midbass driver peeking through, but then again, it has to be there. No other place it could be.
                              The AMT's are suspended by what appears to be a carbon fibre structure.
