Jim's new CBT Arrays
  • #16
    Another fantastic build Kevin! This is oozing with Kevin's signature attention to care for every little thing.
    Originally posted by xmax View Post
    I'm no expert on line arrays and with all due respect, seemingly with all that Sd one could be designed with ample low end,
    is there something with a line array that makes that not practical? I see subs are often recommend with them.
    There is not as much Sd as you would think. There is only 20cm^2 on each driver. With 24 of them you have 480cm^2. While that's the equivalent Sd of a 12" woofer, these 2.5" drivers only have 2.65mm of Xmax. Therefore, the displacement is only 480cm^2 x 2.65mm = 1272, which is about the same as a 8" woofer with 5.8mm of excursion (220cm^2 x 5.8 = 1276). To look at it another way, a single Dayton RS225 has more bass capabilities than the 24 drivers combined.
    But wait! This is a sealed speaker. Therefore, it is only equal to a single average 8" woofer in a sealed box! A ported speaker can play 3-10dB louder than the sealed equivalent in the bass region depending on the size of the enclosure and port. Let's be conservative, and say the ported speaker reduce the displacement requirement by half (in reality it is more, a lot more if it is around tuning). Taking that into account, now the CBT's bass capabilities is equivalent to a 6.5" woofer with 4.5mm of excursion, which is very average for a 6.5".
    While a CBT looks big, it doesn't actually have nearly as much displacement as you would think. On the other extreme, there is my speaker, which has the equivalent displacement capabilities of a sealed 12" subwoofer with 10mm Xmax in a speaker the size of an overnight sensation by stuffing it with drivers. That said, even if the displacement is available, utilizing them is not easy as the currently available commercial DSPs don't have the proper protection circuitry to allow for a lot of bass boost without the risk of easily bottoming out the speaker.
    • #17
      I understand that, why not use some bigger drivers?
      Guess xmax's age.
      • #18
        Then you need tweeters, and a CBT with tweeters creates additional complexity and substantially more cost.
        • #19
          Originally posted by Jim Griffin View Post
          Don,
          Have boxes. Will travel.
          Jim
          Holy cow, Batman! Just have to find a venue now.
          Tangband W6-sub
          • #20
            Don, realize I have lots to do before the music plays--finishing, assembly, testing, etc. will consume the next month. I may have them ready to show at the Kentucky DIY in mid-November but with minimal listening time. With holiday stuff and a Florida vacation it will push things into next year.
            • #21
              Line arrays are build and designed to present different type of virtual imaging. As far as frequency response of a line array speaker goes, it presents challenges just like conventional speaker designs.
              Having said that, you could build a full range driver array, 2-way or 3-way array or even design a bass array.
              What you do get with the array is a huge life-like image and incredible dynamics.
              http://www.diy-ny.com/
              • #22
                Originally posted by r-carpenter View Post
                Line arrays are build and designed to present different type of virtual imaging. As far as frequency response of a line array speaker goes, it presents challenges just like conventional speaker designs...
                Absolutely, like any other tool.
                What is the arc angle?
                • #23
                  36 degrees
                  My "No-Name" CC Speaker
                  Kerry's "Silverbacks"
                  Ben's Synchaeta's for Mom
                  The Archers
                  The Gandalf's
                  • #24
                    They look great... but I bet you have almost as much engineering in the box and packaging as in the actual speakers. I hope Jim keeps the boxes for any future travels!
                    TomZ
                    • #25
                      TomZ
                      Thanks Tom. Yea, I highly underestimated time and materials on the packaging for these but will have a better feel for something like this in the future. "Adequate packaging" takes on a whole new definition when it comes to enclosures being transported by UPS or FedEX, man they are rough on stuff. Jim did tell me he plans to reuse the packaging for transporting them to future events.
                      The Archers
                      The Gandalf's
                      • #26
                        No worries - I've been trying to have a DIY for several years.
                        With some luck, Spring next year may work for everyone.
                        Tangband W6-sub
                        • #27
                          Jim, what significant changes would you make to your line array white paper? Do you intend to publish the changes to account for the comb filtering? Thanks.
                          Hong
                          LM4780 Parallel Chipamp
                          Sonata Soundbar Project
                          • #28
                            Hey Kevin and Jim! These look like an excellent successor to the CBT array project. Not sure I'll be able to make any of the mentioned DIY events to see them in person, but maybe MWAF 2018 or InDIYana 2018? Thanks for sharing the details that you have thus far. Keep up the great work!
                            The Super Bees - Garage 2 way
                            • #29
                              Don't some of these designs use tweeters?
                              Guess xmax's age.
                              • #30
                                Yes.... Don's own: 19 mids and about 117 tiny tweeter thingies(what fun with all that soldering): http://www.xlrtechs.com/dbkeele.com/images/_MG_2364.jpg
