Large Monster Stereo Speakers. What's the largest you've built?
  • #16
    Why the smiley face?
    • #17
      The largest speaker I ever designed was these. I didn't build them, but I did the crossover and overall design. I think about them all the time. They were wonderful. Sadly, the tweeters are NLA (and the mids might be soon as well). But maybe someday, they can be reborn with newer, easier-to-obtain drivers.
      http://techtalk.parts-express.com/fo...lly-named-them
      Twitter: @undefinition1
      • #18
        and your 6'4" , 6'5" ? what were the 3 tweets like ?
        Paper Towers
        RS180P/28F surrounds
        Boombox
        • #19
          Originally posted by Squidspeak View Post
          Edit; wanted to ask were these a Vapor audio product and do you guys (Vapor) do your own cabinet work and or finishing, BTW it is very nice who ever is doing the work.
          • #20
            The largest speakers I've built we're the Omegarays which stood 6'4" tall. They had (10) Aurum Cantus AC130 MKII woofers with (8) Founteck CD2.0 ribbons. The bottom compartment contained a 12" AE (Stryke) sub which was actively powered.Rick Craig designed the crossover for the linearray portion. This was back in 2003 and I used them until the Statements took their place.
            Jim
Name:	Omegarray 003 (Large).jpg
            • #21
              Yup, 6' 4 1/2" tall. The tweeters and woofers were all pretty good vifa drivers at the time. It actually didn't sound as bad as you'd think it would. No distortion that I ever heard. I was around 30 yrs or so old at the time. All oak and particle board. Weighed a ton, the base was solid oak and that alone must have weighed 50 lbs...At least the cabinets were solid.
              TomZ
              • #22
                Dan
                • #23
                  My take on big speakers: Click image for larger version
Name:	Left Cavehorn Foam Upright.gif
                  RSS390HF-4 up to 150Hz, SEAS W18E001s from 150Hz to 750Hz, modified Altec 511 horn with TAD TD2002 driver from 750Hz on up. The center of the horn sits at ear height, 35". Active crossover with all slopes LR24, using a modified DCX2496, with QSC RMX850 amp for the bass, Parasound Halo A21 for the mid, and First Watt J2 to drive the horn. I intended to finish them, but once the engineering and construction was done I just never got around to it. Probably never will
                  Francis
                  • #24
                    The picture is my avatar in my profile. 6 inches by 24 inches by 8 feet. 34 individual tubular cabinets, 40 tweeters, two 10 x 32 x15 inch ported woofer cabinets.
                    • #25
                      I'm 6'2" and these are just a shade shorter than me, so very likely 6' tall. Dual 12's and single 18's. This is my best friends in-laws garage stereo. (No I'm not joking). The largest setup I've built from scratch.
                      Your results may vary.
                      • #26
                        LOL, is there enough room left to wrench on a car in there?
                        • #27
Name:	Altec Complete 011.JPG
ID:	1350428 My recent Altec Lansing build. 48 inches tall, 36 inches wide, 24 inches deep. It's a corner cabinet with Altec 416-8Z woofer, 511B horn, 802D driver, and Beyma CP21/F super tweeter slot horn.
                          GeeDeeEmm
                          • #28
                            Originally posted by gdmoore28 View Post
                            [ATTACH=CONFIG]n1350428[/ATTACH] My recent Altec Lansing build. 48 inches tall, 36 inches wide, 24 inches deep. It's a corner cabinet with Altec 416-8Z woofer, 511B horn, 802D driver, and Beyma CP21/F super tweeter slot horn.
                            GeeDeeEmm
                            Good to see someone else using the venerable 511B! Very nice looking, too! Is the super tweeter between the horn and woofer?
                            Francis
                            • #29
                              Eric
                              • #30
                                2 Subs - each 46.75" x 22.5" 17.75" 10.8 cu ft external - 21.6 cu ft total
                                ( largest attainable from 2 sheets of MDF )
