any crossover nerds want to take on a mentee?
  • #31
    Can I make a suggestion- I installed a dremel cutting wheel in my drill press, and used that to cut the rear off a couple horns when I did the Mr East project. You get a uniform distance that way, and it's otherwise a bit awkward to cut where you want it. I agree that it looks like the horn and 5002 combo will mate well.
    • #32
      I have that horn it but didn't even occur to me to try it, great idea. Thanks.
      John H
      • #33
        That's pretty much what I was gonna do, except I am probably gonna use a slitting wheel on my milling machine, just to be more fancy-schmancy. Either that or I can use my 7x12" horizontal/vertical bandsaw.
        • #34
          Preliminary fit-up of an Airborne RT-5002 AMT with a modified P.E. H110 horn:
          The aspect ratio is off (horn is wider than the AMT when the height is correct), but it's nothing a little work can't fix:
          Another AMT that might work with the same horn, the Dayton AMTPRO-4, albeit with multiple horns "spliced" together vertically:
          More info/data coming soon....
          • #35
            Preliminary data for three AMT's: Airborne RT-5002's, Beyma TPL-150H's, & Dayton AMTPRO-4's. DCRs measured by DATS V2.
            Airborne #1, by itself with just faceplate, plus faceplate removed and added horn. 2.06V into 4.2Ω, 1m.
            Airborne #2, by itself with just faceplate, plus faceplate removed and added horn. 2.06V into 4.2Ω, 1m.
            All 4 curves superimposed.
            That is with just a rough, rudimentary fit. I am going to fill in the throat of the horn somehow to better match it up to the width of the AMT apertures to hopefully get better horn loading. The only penalty is above ~16-17kHz, where you lose 1-1.5 dB.
            • #36
              Beyme TPL-150H's. Only tested as-is, with the Beyma horns. DCR as measured by DATS V2.
              Beyma #1 and #2. 2.19V into 4.8Ω. 1m. (interesting to note that Beyma rates these as 8Ω nominal drivers, which doesn't make sense since it is pretty much purely resistive @ ~ it's own DCR. I would call these "4Ω" personally)
              • #37
                Dayton AMTPRO-4's. 2.06V into 4.1Ω, 1m.
                (near future....)
                Up next [2nd] round of testing:
                • re-test Airborne RT-5002's with tighter throat matching on H110 horn.
                • re-test Beyma TPL-150H with custom larger horn.
                • re-test Dayton AMTPRO-4 with custom larger horn.
                During the 3rd round of testing:
                • re-test an Airborne RT-5002 pair, vertically aligned, no faceplates, with custom horn surmounting both drivers.
                • #38
                  All of those AMT's have a very useable response out of the box. If you're looking to get the most output from the AMTPRO, put a sealed chamber over the back side to turn it to a monopole. As a dipole, I found I got a little more output in the 2-4kHz region by leaving both layers of felt in place on the back side (unsure if you tested with it in place or not). I imagine it can only be improved from a completely sealed chamber. You'd want to do this when you mount a horn to it as well anyway.
                  Don't waste your money on a new set of speakers, you get more mileage from a cheap pair of sneakers. Next phase, new wave, dance craze, anyways it's still rock and roll to me!
                  • #39
                    Yes both felt pads were in place. A test box will surely come later on as well. All of them show good potential for my project, one way or another. My main sub-goal for now is to determine how low of a Xover freq I can pull from any one of these various setups because as I hope you remember, I'm shooting for a 10" midbass driver to match up the high-frequency unit. So I'm still doing this balancing act on this end of the spectrum. I know one can start on the bass side of thing because those are never attenuated due to baffle loss to begin with, but I can always tweak things out with EQ and power.
                    • #40
                      Just picked up these babies. Not saying these will be the ones I end up using, but they do have a good shot I'd say.
                      I hope to have some FR measurements once I build some test boxes, likely sealed.
