OT: Sound Card For PC
  • OT: Sound Card For PC
    I am running windows 10 64bit and my old creative sound blaster card doesn't have support for Windows 10.....so I'm using onboard sound. I'm thinking about getting another sound card and not sure what to get. Looking for suggestions for a new sound card. Any one have one that they would suggest ?? Thanks
    Don't know what software you are running. Sound Easy has some specific suggestions, they are for older cards but still good. I can't look on their website from here in the office, but you can check their site for the information. bodzio is the publisher.
      Just an overview
      http://windowsreport.com/best-sound-...or-windows-10/
        Why not get an outboard high performance DAC and feed it the digital sound signal via USB?
        These are the ones I use and am very happy with them:
        Resonessence Labs Concero HD
        LKS Audio MH-004 - Dual ESS Sabre ES9038Pro chip DAC
          I have 4 sound cards. I used them to test speakers using an input for monitoring. Ran with too much voltage and blew the input but output still works. My last sound card is a M-Audio Delta AP 192 bought used from a man that got a computer without PCI. It is not as perfect as my Asus high end cards but handles 4 volts so it does not blow. If you get a mother board with very high end sound that will work ok too. Do not get a cheap sound card for $ 38 because they have poor sound and will not handle much voltage at all.
          I have to run the Delta in Windows 7 compatibility. Easy to do in Windows 10.
          I was tired and got tired again so now I am Re tired.
            The very pricey new EVGA gaming sound cards are true state-of-the-art sound quality, and you pay for it. You might want to look at some of the top-end gaming sound cards, as they are multi-discreet channel with really high fidelity sound.
              If you need nothing but 2-channel, the Soundblaster X-Fi HD is a stellar external unit. Drives headphones wonderfully (seriously well), has switchable RIAA equalization on the line-in, should you ever want to digitize vinyl or whatever. Even has a ground lug like a good phono pre.
              It's a couple years old now, but it needs no drivers so even if Soundblaster decides to discontinue support, it'll continue being a good device. I love mine. I use it at work, and am thinking about another for home.
              nothing can stop me now
                The X-Fi HD is what I run on the wifes PC. Nice unit indeed.
                Not sure about Win10 support, but it is hard to go wrong with most of the Asus line up.
                  I've been playing with a Behringer UMC22 this week. They're only $40, so I thought I would give one a try. It has some issues on my older Dell Win 7 laptop - freezes the audio stream when using the mouse. It's probably driver related. It sounds OK and has more output than my Focusrite 2i2, which has been giving me strange results with ARTA the past few weeks. I'll try the Behringer on my Win 10 desktop tonight and see if it has those same issues.
                    if it just for playback and you want something small get an Audioquest Dragonfly.
                      Tom -
                      Are you using the ASIO4ALL driver for your UMC22 on your win 7 laptop? For Win 10 I found this UMC 22 comment (dated 2016) on a forum:
                      "You have to contact Behringers support and ask for them for the correct drivers for Win 10, since they don't have them on the webpage for some reason. I had the same problem myself:"
                      Hope this helps...
                      "Everything is nothing without a high sound quality." (Sure Electronics)
                        I second the DAC idea. I'm using an Essence DAC that can pull audio from USB, TosLink, or HDMI, has single ended and balanced out, up-converts the input stream to 384K 24-bit and boasts among the highest signal to noise ratio available. Comes with a remote. Sweet unit.
                        http://www.essenceelectrostatic.com/...t/hdacc-ii-4k/
                        When doing measurements, I just use the on-board mic input of the built in soundcard on the PC.
                          Tech talk has a bot problem.
                            Originally posted by ernperkins View Post
                            Tom -
                            Hope this helps...
                            Thanks for the pointer! I did find a link to an old driver (2.8.40) for Win 7 on the Behringer forums and it's working much better on the laptop now. I've been listening for the last hour and no problems at all. Very pleased for $40! I'm running out of time to tinker this week, but I'll try it on the Win 10 system this weekend.
                              Funny how this thread was bumped by a bot and has been revived.
                              To add to the feedback, I just run HDMI out of my video cards. This assumes that whatever you are playing music through has an HDMI input, however.
