Stuffed t-line to flatten midrange resonant freq impedance peak near xo cut off
  • Stuffed t-line to flatten midrange resonant freq impedance peak near xo cut off
    in a double peak vented t-line you definitely reduce the secondary peak down to where there is a single peak and the single peak is reduced as well. The resonate frequency also drops a bit. Whether or not you need impedance compensation is a separate discussion
    John H
      Gotta think that with enough stuffing you just end up with an aperiodic cabinet.
      Francis
        Can't get rid of the primary resonance completely. However you don't necessarily need a compensation network. Most times you can design the crossover such that the impedance peak is taken care of by proper component selection. There are always exceptions of course.
          I would imagine that despite the cabinet construction, there will always be an impedance spike that would need to be managed on a component basis. I'm sure some of the guys that are crossover wizards would know more about driver impedance and cabinet design than myself though.
            I like the idea. What frequency are you trying to dampen? I would worry that the stuffing will dissipate the wave if it is too high frequency. I suspect that no reflected wave = no impedance correction.
              I have several TB W4 1337 titanium drivers sitting around I would like to put to good use. Measured Fs is 73hz.
                I think a 73 Hz wave should travel through the stuffing pretty well. You will probably need to experiment with both stuffing density and line length to get something close to the desired result. Hopefully, you have some way to measure the impedance.
