Help with sub 200hz
  • #16
    Daytons kab-215 Sent from my iPhone using Tapatalk Pro
    • #17
      Speaking with two techs on the phone at PE, they both seem to believe the amp is the weak point and bumping up to the kab-230 amp should help deliver that midbass im lacking. I hate having to buy another amp. Does this sound reasonable? Sent from my iPhone using Tapatalk Pro
      • #18
        There is one review on the KAB215 that also seems to have limited bass. But other's here have not had an issue IIRC with bass (but perhaps they were using a sub as well). Wait for others to chime in before buting again.
        • #19
          Add the notch x-o for 5 db baffle step before buying another amp. PM me your address if you need the cap and resistor.
          John H
          • #20
            What is the PS you are using to drive the KAB? Output voltage and amp rating?
            • #21
              You could try an experiment. Get a large sheet of cardboard, like from a refrigerator box, and cut out a slot just big enough for the baffle to fit through, then play the system to see if the bass comes up. You would essentially be simulating a wall mount.
              • #22
                Two people have told you where the problem is, but you don't seem to believe us. Take a very close look at post #11, and try to imagine why your filter did not work.
