Is my Phase too fat?
  • #16
    Originally posted by Wushuliu View Post
    Why? To protect the tweeter?
    Yep.
    • #17
      Originally posted by xmax View Post
      You see even the much cheaper Seas (and the Transducer Labs) has a lot less distortion at 1K.
      The SB tweeters are some of the best but I would never cross them below 3K at 12 or more dB
      per octave.
      Have to disagree there. I've crossed the sb26stac at 1.8k, 3rd order electrical in a series network. No issues with distortion or otherwise. They have the ability easily.
      • #18
        JeffB: "I've said this a number of times in discussions about my Kairos, but the Satori can cross lower naturally (without the aid of waveguide) than any other tweeter I have used"
        Troels: "from my SBA-10 construction I learned the TW29RN can go really low without problems."
        • #19
          Agree, Jeff crossed the Kairos at 1.8k, 2nd order electrical.
          • #20
            I have used the original SB STC25 tweeter and now have the STC26 in its place. In my auditioning I tested it LR4 @1500Hz and higher. I detected no audible stress, but extended use might show a heat problem. I ended up using the LR4 @2K. It's part of my design hosted by Zaph. He provided the drivers and requested that I post a design. I took that a step further and documented the design and build fairly thoroughly. That was eight years ago!
            The Chameleons
            dlr
            Dave's Speaker Pages
            • #21
              So a third order cap would be needed even though I'm already more or less at LR4 at 1.5khz and ~30db down at 600hz?
              I just noticed Troels crossed his TW29 second order electric/LR4 Acoustic at 1.7khz (attached along with my XO response)...
ID:	1355354 Click image for larger version
Name:	Troels MW19 TW29 2.png
              • #22
                You'll probably be happy with what you have, though you might consider adding an LCR filter to address the lump in the 2.5k to 3.5k region. The region just above the crossover freq will have a wide directivity compared to the frequencies below the crossover due to the transition from the woofer to tweeter. I find that lowering the level here often makes the sound more natural, basically you are compensating for the overall radiated energy (power response).
                You will see something to this effect in Troels SBA-10:
                Don't waste your money on a new set of speakers, you get more mileage from a cheap pair of sneakers. Next phase, new wave, dance craze, anyways it's still rock and roll to me!
                • #23
                  Interesting. That's kind of where I'm headed right now. I feel like I'm almost there but need to drop the tweeter a hair. Your directivity comment has me thinking now because currently one of the bonuses of my current XO is when I stand up in the listening position (~2m) the imaging is fantastic, extending behind the speakers almost 3-D. I haven't really experienced that before with previous builds. In sitting position the tweeter has just a little bit too much energy up top. Just a hair on some tracks (Cymbals, Aja for example).
                  • #24
                    Ah good, I didn't realize you had built this already and were listening. If that's the case, you can always apply some EQ, whether from a PC source or DSP or receiver, etc. to determine what needs to change in the crossover to make the sound perfect, but I would start in the 2.5-3.5kHz range. Too much energy here will make the speaker sound overly forward, and you'll only have to drop the level 1-2dB to make a world of difference. You can also try dropping the entire tweeter level a bit if you find its just a bit too much overall (cymbals, etc).
