Interesting Power Supply Issue...
  • #46
    Tom,
    My testing points to the TDA7402 module as the culprit.
    I tested two TPA311X 2.1 amps with three different power supplies. One amp is an TPA3118 Sanwu 2 x 50 W + 60 W TPA3118 (pictured, $11 ebay). The other is the new PE DTA 2.1 BT 2 x 50 W + 100 W amp. The PE amp was removed from its enclosure (ongoing reverse engineering project sponsored by Kevin K).
    The three power supplies: (1) The DTA's 24 V 4 A PS with a huge ferrite bead and 3 prong plug; (2) A PE 24 V 5 A brick, 2 prong, no bead; and (3) An 15 year-old Dell 19 V 3.3 A, 2 prong, bead was removed to put on a 5.5 plug.
    The DTA, at maximum volume and nothing connected to the RCA inputs was dead quiet with all three PS's.
    The Sanwu, at maximum volume and nothing connected had some pink noise. The same with all three PS's. I had to put the 4" full range right to my ear to hear it (but I'm half deaf). With a the RCAs plugged into my laptop and no signal, it became dead quiet.
    I think the TDA7402 board is picking up emissions from the bricks switching due to a high gain setting on the chip - either via the air or, more likely, via the PS + rail on the board. Could be just a poor design. I believe the TDA7492 module has higher gain than the 26 dB typically used for TPA311x modules. On my other forum, it's noted that the TPA311Xs on higher gains are noisy.
    I would test the TDA with a low impedance source connected (head phone output from a laptop/PC or phone). If the noise is acceptable with that, I think the faceplate has a abnormally high output impedance. That was indicated when you tried 1.3K? resistors to ground but couldn't get the volume up. In that case, I might try different value resistors on the inputs to find a happy medium between noise and volume from the faceplate (I can mail various values from my stock for you to try).
    Mike
    • #47
      Hey Mike, thanks for doing all this.
      Oh, I tried the radio in several locations in the house, several different 'zones' or breakers on the service panel.....they were all noisy.
      Well, I just got in the DC-DC regulated convertor, hopefully the ground isolator for the audio input will be here by Tuesday or so. I'll try again what that comes in. I'm hopeful.
      I also ordered another of the TDA7402 amps, the original ones that had noise with nothing hooked to them.... I remember messing with these to see if they could be used in single channel mode like the product description says... I think you'll remember that post... I tried to hook it up a few different ways, and I'm wondering if it's possible that I goofed it up somehow.... anyway, I have another one coming so I can be sure.
      I've been doing some woodwork/veneering etc. while I wait for parts to come in so at least I'm trying to be productive!
      BTW, I think it's great that you're taking a peek under the hood of PE's new 2.1 amp, that really looks promising if the Lowpass filter can be brought down to a reasonable range from the 180 Hz or whatever it is. You're really have something there for the Bluetooth users, the phone could be the remote control in a way with that.
      I searched page after page of 2.1 amps/preamps, etc. on the 'AliX' and 'Zon' sites today... there are dozens and dozens of various implementations of that arrangement. Someone is making a lot of little amplifiers in this world!
      TomZ
      • #48
        Neal, just got the little DC/DC converter, I didn't realize it was going to be so small!
        Here it is next to the little linear regulator and a quarter for size comparison.
Name:	IMG_0633 (Small).JPG
        I just wanted to check with you on wiring it up. I'm assuming that I just connect the voltage in + and - as well as the voltage out + and - and I'm good? I can just ignore the other leads? Looking at the data sheet, it isn't clear what the other leads do. Here is the data sheet for it: https://media.digikey.com/pdf/Data%2..._Series_Ds.pdf
        Also, do I need to be careful about soldering to this? My plan is to solder some wires to the leads I need, and heat-shrink those and the remaining leads to keep the terminals from contacting anything, with probably a few wraps of electrical tape around the area where the terminals come out of to give it some strength against bending the leads. Will this thing get hot enough to need to be isolated from wires, etc.? Questions, questions, right? I should be paying you guys college tuition money!
        I should get the line-in input device Tuesday hopefully so I'll give everything a run then.
        TomZ
        • #49
          Nah--that's a big honking component in my world. I'm used to SMD stuff that requires magnifying lenses Anything that can fall on the carpet and not get lost is big!
          ​The N.C. pins are "no connect", so don't worry them--no heatshrink tubing required. The R.C. I assume is "reserved connection", probably a pin used for testing. It should be isolated.
          ​I don't think it requires extreme care since the housing is an epoxy that is heat resistant. I always use a temperature controlled iron, and I would recommend one of those. But a simple 25W soldering pencil or other electronics-oriented soldering equipment should be fine.
          Nope. With 24V input it is 83% efficient. It the load is 150ma, the convertor will only dissipate only 0.3W (12 x .15 x .17).
          ​For this type of component, I usually make the solder connections and then hot melt glue the part to the chassis or some other device. Cover the terminals with hot melt glue if you like to give the wires and connections some extra strength. You can even use Velcro to mount the device, as long as the wires aren't too heavy.
          ​I hope this works out for you. Grounding is always more difficult than you would expect, and unfortunately, it is not taught in college. I'm assuming the problem is due to unwanted current flowing in the grounds rather than radiated interference, but this will at least help isolate the problem.
          • #50
            Originally posted by neildavis View Post
            [LEFT]
            Can't be 100% sure, but I tend to agree (and mentioned this near the start of the thread). Have worked on many mixed digital and analog HW designs for work and have never seen radiated (or conducted, it doesn't have to be radiated) interference remotely near the levels that would be required for the issues Tom is seeing. If it is interference, it would probably be conducted vs radiated as noise level depends on what is plugged in
            • #51
              First, these are both DC based units. That implies that signal ground between them is the same ground when connected to the same DC supply; the amp having decoupling caps on the inputs to negate any DC bias. I do agree that the noise, if from the PS, is conducted. But radiated noise can be a problem. IIRC, Neil has written about issues of radiated noise from the digital output filters due to the chips switching frequency.
              Gent.'s ... for this problem I'm forming a different opinion than ground issues.
              In this module, the TDA7492 chip's gain is set fairly high. That tends to make the module susceptible to noise. Having a low impedance source helps. That was evidenced when Tom tied 1.3K resistors to ground on the inputs thus reducing the noise somewhat. But the high gain in a single stage is always going to be problematic. The amp was noisy without the face plate connected. And, the face plate seems to be a high impedance source as evidenced by the lack of volume with resistors to ground on the amp's inputs. There's a well known YouTube video that measures an amp's noise reduction by replacing a 50k input pot with a 10K pot on an amp. That swap essentially insures a maximum of 10K input resistance to ground
              Based on info from following other forums and having tested the other amps that performed well, several things are evident. First the chips I tested, although different, are set to a lower gain (26 dB compared to 31.3 or 33.6 dB in the TDA7492 module). That's significant. 26 dB is ~ 20x gain while 33.6 dB is ~ 48x gain. To get the overall gain up, the modules have op-amp stages feeding the chips. Those stages are also lower gain, perhaps in the neighborhood of 12 dB, So there isn't a single stage with excessive gain that is sensitive to induced noise (conducted, radiated, take your pick). And the op-amps provide a low impedance source to the chip's inputs further resisting induced noise. On the $11 ebay Sanwu module, there was slight noise with unconnected inputs but it was dead quiet with the laptop connected. The TPA311x series has been out a while now. And every current design sets the gain at 26 dB (or lower) based on early experience with higher gain settings and noise.
              If it wasn't 0o degrees out, I'd suggest taking the amp outside and tap a 12 V car battery. If it's still noisy, then the chip's switching is inducing noise into the module. If not, I suspect the system would be quiet with both the amp and the face-plate connected to the car battery.
              I would like the amp tested on the PS with a known low impedance source - headphone output from a phone or laptop (on batteries). If still noisy, it's the amp's high gain susceptible to the PS noise. And shorted inputs would determine the basic noise floor for the module.
              Side Note: Tom I didn't mean to steer you to 2.1 amps. I just happen to have those two units on hand to do the PS tests in my previous post.
