Mordaunt-Short MS3.2 tweeter replacement...
  • Mordaunt-Short MS3.2 tweeter replacement...
    One of the tweeters for my 27 year old MS3.2s seems to have lost a bit of its output capability. The tweeters are Audax TW6 drivers with removable custom flanges. PE does have a replacement that should work (once the flange is changed) - https://www.parts-express.com/advent...-iii--299-2002. However, as I'm planning to redo the x-over anyway, should I go with a more modern tweeter?
    ​I found two on the PE website that have dimensions that suggest that they might fit without extensive modification to the speaker box:
    Dayton Audio ND20FA-6 - https://www.parts-express.com/dayton...eeter--275-030
    Peerless by Tymphany NE19VTS-04 - https://www.parts-express.com/peerle...eter--264-1006
    ​I'm basically limited to choices that have a flange that's 60mm or less in size, and the mounting diameter has to be 46mm or less.
    ​Should I go for the upgrade, and if I do, which tweeter do you suggest I use?
    The second picture shows the response of one of the speakers with and without the tweeter.
    Brian Steele
    www.diysubwoofers.org
    How audible is that drop? Does it jump-out at you?
    I'd use a different tweeter just because the stock tweeter looks rather uninspiring.
    I know, hardly scientific.
      ​I sometimes noticed a difference, but now I've measured the difference, I notice it all the time, LOL.
      LOL - "uninspiring" is quite a fitting term. The original tweeter is also surrounded by an additional rubber flange, and the 27 years have not been kind to it. I'm really stuck on if I should just take the lazy route and replace the original tweeters with what essentially are likely to be plug-in replacements, or go with a solution that's going to involve a bit more customization, knowing my carpentry skills (or lack thereof).
      ​Another possible solution presented itself - the SEAS 27TFFNC/G, available off the other DIY site. These are actually pretty good and I use two in my car, but at $40 a pop seem a bit expensive for this particular project.
      Brian Steele
