SevenSixTwo - InDIYana 2018 Coax Design
  • Originally posted by skatz View Post
    Are all four edges of the baffle rounded? If its just the vertical edges, then rotating your veneer 90 degrees so that the grain is vertical would make it much easier to wrap around those roundovers. If all four are rounded, then orient the grain so that the shorter edges are the ones that get curved across the grain, as Keith mentioned.
    Hey Skatz, The short edges of the cabinet are rounded over (so the top and bottom edges of the front,top,back,bottom). All the long edges are treated with a 3/8" chamfer. I like your thoughts about grain direction too. I normally pay attention to that sort of thing, but I'm going for pretty here with the direction of the curly pattern For what it's worth, I think the actual grain pattern of this curly maple is running in the right direction... I just got unlucky with a few curls here and there.
    Originally posted by jhollander View Post
    You can't pre--dye then glue? Dye should be heat resistant, not sure about any others.
    Hey John, I think you're asking if I could pre-dye the veneer before installing it? I hadn't considered that before. I suppose that could be done... can't think of a reason why not other than it not being the standard order of construction then finishing. In this case, I've been following my plan of installing the veneer, then dyeing it. This way I can get the final dye color on the cabinet before trying to color match it for best blend with the colored epoxy. hopefully I can use a super small amount of epoxy that won't require lots of sanding to smooth out. I'd like to avoid removing any dye color on the wood by accident!
    The Super Bees - Garage 2 way
    • Originally posted by KEtheredge87 View Post
      ​Maybe I'm reading this wrong but it sounds like you're confused about the grain direction. Your veneer's grain direction is perpendicular to the curls that are running across it. Therefore, when you apply the veneer the way you did, you are wrapping the radius across the grain, not with it. If you'll take a small piece of scrap and wrap it in the opposite direction of how you applied it to your cabinets, you'll see you can easily wrap it around a much smaller radius (perhaps even as small as a pencil). Not trying to be critical and FWIW, I definitely agree with the direction you have applied the veneer on these cabinets, they should look great once finished.
      One more tip since this is paperbacked veneer, when applying the softener, you'll need to be careful not to put so much on that it makes the paper wet on the back side. I applied light coats with about an hour in between each until I felt like the wood was saturated. Then it has to sit for a while before attempting to bond it to the cabs.
      My "No-Name" CC Speaker
      Kerry's "Silverbacks"
      Ben's Synchaeta's for Mom
      The Archers
      The Gandalf's
      • Originally posted by Kevin K. View Post
        Thanks Kevin It's entirely possible I'm bass-ackwards on my grain direction. I'll have a closer look when I get home tonight to recalibrate my brain. On the veneer softener, I read the how-to on veneersupplies.com website, and I believe it says I'm supposed to lay the sheets between some cauls and clamp it flat while it dries. Did you do that when you've used it before? I recall the part about going easy on the application when using paper backed veneer... guess I just don't want to ruin anything!
        • What you read about clamping it between cauls would apply to a veneer without a backer. Since this is paper backed, it should be fairly flat already other than maybe some slight curl from being rolled up. I only applied the softener to about a 2" wide area right where the radius's would be. Just measure CTC between radius's to figure out where it would need to be applied. Best of luck!
          The Archers
          The Gandalf's
          • Hey Everyone! It's been a few days since my last post... I've made some more progress on the XO and the cabinets to share, although I had hoped to be a smidge farther along.
            Starting with the cabinets, I went forward with my side panel veneer applications on the test cabinet. This was a lot easier to deal with since there were no curved surfaces involved! I also made a jig to frame out the side panels and trim them with a bushing guided down-cutting spiral bit. All in all, I think it turned out pretty good! The only thing stopping me from rolling forward and applying the veneer to the other cabinets is my curiosity about diffraction impacts with the vertical slots that I use to trim the veneer around the cabinet's narrow sides. I really want to take these back outside and do another "free-field" measurement to get the best data... but it's supposed to be gross and rainy here in Indiana for the entire week! (two thumbs waay...WAAAY Down!) My gut tells me that whatever the impact of those slots happens to be, it won't be drastic enough to make me change my whole cabinet design approach, so I should probably stop wasting time waiting for sunshine and just roll forward with veneering. Getting these cabinets 100% finished through dye, paint, and topcoat in time for InDIYana is probably a stretch, but I'll see what happens. The speakers will definitely be done enough to perform... they may just get their finish after the show!
            On to the XO... I spent most of last Saturday arranging, gluing, and soldering one of the midrange XO's as well as one of the tweeter XO's. I now have one solid set of XO's built, and I am happy to report very minimal change to the response after all the gator clips were removed from the equation! I have a chart on my measurement computer that I forgot to save to google drive, but from memory the response was nearly identical, if maybe a tiny bit louder from 2Khz upward (we're talkin a few tenths of a dB according to omnimic). The measurement line was just barely different from my gator clipped bench XO response. I'm quite pleased with it! I can't wait to get some other ears on it for some constructive feedback!
            Here's a few photos to document the progress while I run out of patience waiting for sunshine to come back!
ID:	1370685 Click image for larger version
ID:	1370687 Click image for larger version
ID:	1370686 Click image for larger version
ID:	1370688 Click image for larger version
            • Great to see you moving forward on these again, was beginning to worry something catastrophic had happened. You don't have time to sweat the impact of the slots, I would move on. If it ends up being horrific once you take measurements, guitar banding might be an option to fill the slots. Probably going to be fine.
              ​Nice looking crossovers! What is and where can we get the perforated panels?
              The Archers
              The Gandalf's
                Great to see you moving forward on these again, was beginning to worry something catastrophic had happened. You don't have time to sweat the impact of the slots, I would move on. If it ends up being horrific once you take measurements, guitar banding might be an option to fill the slots. Probably going to be fine. ​Nice looking crossovers! What is and where can we get the perforated panels?
                Thanks Kevin! Moving on has been the conclusion I came to as well. The perf boards are the new ones PE sells. I just searched for PC boards or crossover boards and found those as well as the little corner standoffs. The woofer xo fit nicely on a 3" x 5" board, the mid used most of a 5x7 board, and the tweeter used all of a 5x7. On those slots, if it really comes out nasty, I do have guitar banding left over from the Jedi mind trick project. Bought it then and didn't end up needing it. Just gotta keep moving. Final push over the next few weeks! Sent from my Pixel 2 XL using Tapatalk
                • Hi Everyone! Hope you all had a nice Easter weekend with your families (if celebrating Easter is your thing ). I had Friday off, so between Friday and Saturday I managed to make some good headway on the project. Of course, this also included a few ups and downs.
                  Ups:
                  - Veneer softener worked wonders on the long wrapped piece for the second of three cabinets. No more frayed and cracking grains!
                  - Crossover construction for a stereo pair is now complete! I copied my placement from the first set, glued it all together, and soldered into place. Still need a few zip ties on the inductors.
                  Downs:
                  - While trimming the veneer in the second cabinet's opening, I must have changed my router settings from "original recipe" to "extra crispy." I cut into a few areas that I was not expecting to be cut... almost like the MDF just burned out of the way! Most of the issue was on the back of the cabinet where the terminal plate goes (no big deal)... but a little bit dug into the slot port on the front. kinda sucks, but not the total end of the world...maybe.
                  Overall, this cabinet could easily be my "test cabinet" now. Just gotta be extra careful with my third and final cabinet veneering before I get into finishing mode. I'm feeling pretty good about getting things done on time. Just gotta keep pushing!
ID:	1370990 Click image for larger version
ID:	1370991 Click image for larger version
ID:	1370988 Click image for larger version
ID:	1370987 Click image for larger version
                  • I hate seeing the router mishap happened to you, it's gotta be a real bummer after all that work. Fortunately you were wise enough to build three cabinets and could afford the mistake. Couple of questions on how this happened. Hand-router or table-router? And what bit are you using?
                    BTW, not sure how you are uploading your pics but I can barely see the slot port damage, it's cut off in the picture.
                    I have a fix in mind for your damaged cabinet if you're interested but for it to look right it would have to be done on the pair.
                    The Archers
                    The Gandalf's
                      Hey Kevin, I didn't upload a direct picture of the slot port damage in favor of other pics that I thought were more important at the time. I've included a somewhat better picture of that slot damage so you can get an idea of what went down there. You can see on the top-right side, the bit actually started cutting into the surface in one spot only. On the bottom right side, the carbide bearing surface must have overheated and compressed the MDF somehow, as the cut line wandered broadly into the cabinet as I pushed the router from right to left, trimming the bottom edge of the slot.
                      I was using a Whiteside SC28C dado flush trim bit in my bosch hand router with plunge base to make these cuts. This bit has a 1/8" pilot portion below the cutting surface that acts as a fixed bearing. It fits into shallow recesses for drivers or tweeters, and trims veneer easily. Unsurprisingly, it can also get very hot from all the friction that "bearing" causes while it spins against the MDF surface. I've used this bit before with good results, but I admit I was going a bit quickly this go-round. I probably pushed the router a bit too much against the material, as the bit itself is showing some signs of overheating. It looks like it's covered in cooked MDF, with a slight hint of blueing on the bearing. Thankfully it's a $10 router bit, even from whiteside, so not a major deal to replace it. I wish there was an alternative to this that included a real bearing to avoid this kind of mistake.
                      I'm all ears for the cabinet fix you've got in mind. If you're thinking about a round-over applied to the slot port, I had originally considered that as part of the design. Once I listened to the speaker with XO involved and didn't get any port noises from the slot with the flush end, I decided I didn't need to pursue the additional roundover. Additionally, I was kind of chickening out on that particular cut... I've never seen a roundover applied after veneer application before. I still remain concerned that there would be some very strange looking transition between the veneer, paper backing, and the MDF where the blade cuts through it all. Have you ever seen anything like that before? Otherwise... what's on your mind?
                      Thanks for following along!
                      • I have cut oversized by 1/8 inch with a template, bushing, down cut spiral bit. Alignment, centering, and clamping of the template over the hole was tough but was doable.
                        John H
                        • For the slot ports, I would have used this bit. It has a bearing and would have prevented the damage. You can pick it up on Amazon also. https://www.veneersupplies.com/produ...outer-Bit.html
                          For the driver openings, ​you pretty much have to use the bit you referenced. Based on the burn marks I'm seeing in your openings, you are using way to much pressure and not moving fast enough. Don't be concerned with trying to get it all on the first pass. The most important thing when using that bit is to keep it moving. If you are planning to continue building cabinets and I suspect you will, build a table router man. It's a lot easier to clear out those driver openings when you don't have to worry about the hand router wobbling due to lack of surface area for the face.
                          The fix I had in mind was to make a fixture to cut recesses around your port and binding post openings and insert a piece of hardwood maple. I'm thinking 1/2" deep. Width would depend on what you like. If you don't want a round-over on the port opening, just open it up 1/4" or so. If you do like the idea of a round-over, open it according to the round-over size plus just a little. This would eliminate the transition problem you were referencing. I have some nice hardwood maple if you need it and could cut the inserts for you on the CNC just leaving you the task of the fixtures and cuts on the cabinets. I don't believe the inserts would look bad and the addition of a round-over on the port opening might look pretty snazzy.
                          The Archers
                          The Gandalf's
                          • Didn't mention it but all of the inserts would of course be flush with the veneer, nothing sticking out off the enclosure. They would look like accents around the openings.
                            The Archers
                            The Gandalf's
                            • And no this wouldn't be for the faint of heart, nor easy. But as John stated, doable.
                              The Archers
                              The Gandalf's
                              • Hey Kevin, Thanks for the ideas. I like the hardwood inlay idea (also think it would look great) and will keep that in mind. Right now I have one final cabinet to veneer, so I may be able to proceed toward my April completion goal without having to go into full scale repair mode just yet. If I can get two cabinets without major mistakes I'll roll forward and come back to repair this one later.
                                To your point on the router table... I really would like a better one! I built a DIY version into the big rolling workbench I made for constructing the Jedi Mind Trick subs. The issue I have discovered is that the individual sections of that table are not flat with each other. Every time I would run a workpiece across the table, I would either get caught on a lip of material, or have the workpiece lift up ever so slightly as it transitioned to a taller reference surface. Being the overly anal engineer that I am... I really can't stand it, so I don't use that router table setup as often as I might otherwise. Beyond that issue, I feel like I get some bit deflection on that table due to the wooden router lift that the table uses. I like for my router cuts to be perpendicular to the work... and that deflection doesn't help.
                                Outside of a rockin' CNC setup... do you have suggestions on router tables that would be better than the one I built? I am getting close to buying a 3HP sawstop table saw (wife is actually pushing for me to buy it) And I see they have an optional router table wing extension for $500. Seems steep (even for SawStop)... I'd like to think I could do something comparable myself for less money, just more project time on tool building rather than project building!
