Next ?
  • Originally posted by rpb View Post
    It's not hard to export, but it's hard to tell you how. There was a section in the starter guide showing how to do it.
    i have it pinned and have read it a dozen times ... i'm not puter savvy !
    i thought i had it today but when i tried to open it in notebook to look at it the file was blank .
    Paper Towers
    RS180P/28F surrounds
    Boombox
    • Originally posted by filmslayer View Post
      Do you have a thumbdrive to save it to, or do you prefer saving it to your desktop?
      • been trying to save it to Documents , that is where all my speaker files go and the only files in there . but yes i do have a few empty thumbdrives around .
        Paper Towers
        Boombox
        • Click export
          click browse
          type in a file name ending with .frd
          save as type all files
          click save
          click "export frequency response"
          Your file will be the same dB as HOLM, so you need to increase it about 90 to 100 dB before doing the above. This can be done in the options tab. This might be what you missed, and it's just off the charts in PCD because it's at a very low dB.
          • will give that a try .
            Paper Towers
            Boombox
              See last edit on above.
              • YEA !!! this is a tweet file , do i need to make any changes in the columns or punctuation ?
                Paper Towers
                Boombox
                • and i just caught your edit
                  Paper Towers
                  Boombox
                  • You might need to delete all the text above the numbers.
                    Post the file here for me to download if you want. I can tweak it with Excel if you have more trouble.
                    • There might be setting to change. I opened an frd file I made while writing how to do it, and there is no text, and no punctuation.
                      • this was the one you asked to see how far down the neo was at cross yesterday . neocd1.0frd.txt
                        Paper Towers
                        Boombox
                        • There are settings to change. Give me about 30 min.
                          • Here. These settings are on the 3 tabs that show up when you click export. Match these, and I think you will have it.
                            • thanks .
                              neocd1.0frd.txt
                              i also in options went to 89db offset ?
                              Paper Towers
                              Boombox
                                thanks .
                                [ATTACH]n1365257[/ATTACH]
                                [ATTACH=CONFIG]n1365258[/ATTACH]
                                The offset adjustment lets you adjust to match a factory sensitivity, or to move a response higher or lower on the graphs in your sim program.
