Next ?
  • Originally posted by filmslayer View Post
    thanks .
    [ATTACH]n1365257[/ATTACH]
    [ATTACH=CONFIG]n1365258[/ATTACH]
    i also in options went to 89db offset ?
    You need to rename the file neocd1.frd
    • Originally posted by rpb View Post
      i just noticed it's saving as a text file . just renaming it does not not seem to work !
      we'll pick it back up tomorrow .
      Paper Towers
      RS180P/28F surrounds
      Boombox
        See fourth line below!
        Click export
        click browse
        type in a file name ending with .frd
        save as type all files (See the drop down box. That's where you change it.)
        click save
        click "export frequency response"
        Your file will be the same dB as HOLM, so you need to increase it about 90 to 100 dB before doing the above. This can be done in the options tab. This might be what you missed, and it's just off the charts in PCD because it's at a very low dB
        • thanks brother .
          Paper Towers
          Boombox
          • for any newer guys that may be following all this . in the 3 years i've been doing this getting good usable files for sims has become one of my greatest frustrations !
            rpb , i got it to store as an frd , then i opened it to look at it .... WHOAAA !
            Paper Towers
            Boombox
            • The file name must end in .frd
              .frd
              I see yours was .0frd
              Also. When you saved the file in HOLM, did you click the drop box, and select "save as all files"?
              • yes to both . Notepad does away with the .frd and " All Files " is the only way it shows up as a FRD file .... i tried just about everything yesterday , to the point of frustration ! also for comparison i opened John's file that i'm currently using and it contained text info ....
                anyway , John mailed me some resistors that should be here when i get home from work . i'll try and get that XO together tonight ...
                Paper Towers
                Boombox
                • i got ahead of my self thinking today was Thursday .... resistors will be here tomorrow ....
                  i thought i got the file right . it loaded , no error and looks similar to w what John's looks like , but when i open in Xsim no squiggly lines ...
                  Paper Towers
                  Boombox
                  • Take out the lines with shift 3 "#"" or put a shift 8 "*" in front of them
                    John H
                    • Originally posted by jhollander View Post
                      can this be done manually for this file ? i know where it is during the export process but would have to generate a new file ... i noticed yours had " * " .
                      Paper Towers
                      Boombox
                      • You can do the editing in notepad
                        John H
                        • thanks
                          Paper Towers
                          Boombox
                          • UHG !!!! i feel like i'm super close but missing something ....
                            this .
                            gives me this in Xsim ....
                            Paper Towers
                            Boombox
                            • you have to reload the file into Xsim. If you name the file the same Xsim uses the old file. I always have to rename the file so I can make sure Xsim uses the correct file.
                              John H
                              • renaming did nothing ....
                                Paper Towers
                                Boombox
