Next ?
  • #76
    the 3ohm is part of the LCR ? and not separate ?
    Paper Towers
    RS180P/28F surrounds
    Boombox
    • #77
      The padding resistor is in front of the mid x-over on this sim.
      There's not actually a R on the midrange LCR. The resistance shown is whatever dcr the coil has. Smaller R yield a deeper notch. I edited post 75.
      • #78
        I'll see if I can take a screen shot picture of the schematic used for PCD.
        • #79
          Tweeter
          • #80
            The 3 ohm in the tweeter LCR can be adjusted to fine tune output near 20k. If you want more at 20k, raise the R value to 5 or 6, etc.
            • #81
              thats confusing AF ! 20 parts in a tweeter circuit ?
              Paper Towers
              Boombox
              • #82
                Look to the left of the values in my sim. That identifies which part it is. The schematic shows all locations available. Only a few are used.
                The mid notch is parallel leg 2. Could be leg 1 or 3. I happened to use leg 2.
                • #83
                  This forum software and my computer don't work well together. I have to reload, and log in again, and post within about 20 seconds, or it signs me out "due to inactivity". So some of my posts are rushed. Others, I copy, then reload, then log back in, then find the post I want to reply to, click on it, paste the copied reply, and click save. I've likely logged in more than 30 times in the last 2 hours.
                  • #84
                    • #85
                      i used -.10" on the mids and -.75" for the woofer assuming the tweet as 0 .. but after a good look at the tweet it sits back a bit so i'm not really sure .
                      Paper Towers
                      Boombox
                      • #86
                        i used to have the same problem also would log me out after what seemed like only 30sec. , do you check the remember me box to the left log log in button ? if not do it . i've been logged with no issues for 3 days now .
                        Paper Towers
                        Boombox
                        • #87
                          rpb , 2nd order mid and woofer and 3rd order tweet correct ? i should be able to suss it and get it laid out in Xsim . not sure if i'm gonna have all the parts on hand so we may need to tweak a bit 4.7mH for 5 and .2mh for .3 are two know already ....
                          Paper Towers
                          Boombox
                          • #88
                            My sim was just to give me something fun to do, and hopefully give you some ideas to try. Change whatever you need. I can look at your sim in PCD if I can read the values.
                            If you do a screen capture, and paste it in Paint, you can save it as a jpeg, and upload it to this forum.
                            Some of my second order filters may have an added resistor making them a damped 2nd order. This comes in handy on occasion.
                            One other thing. I play with PCD, but do my filters largely by trial and error. My driver zmas are not accurate, so I get less agreement between PCD, and actual response. So, I measure the filtered driver response to see if each driver is rolling off the way it should. Then I measure them together. At some point, I reverse a driver to see if there's a decent null. Then I listen while looking occasionally at the measurements. If I hear something slightly off, I can sometimes see it in the measurement, and make a small tweak. This is time consuming, but that's OK. With 3-ways, I make some additional close mic measurements to help me see what is happening down around 300hz better. My gated measurements become less accurate that low. But some how, some way, I arrive at a finished x-over. Usually, I scrap a 3-way design due to x-over complexity. I also prefer smaller speakers in my room, although I get the urge from time to time to make something massive. I think if big speakers weren't so heavy, I'd build more of them. I have a 7 cu-ft sub in my closet for HT use, but seldom need it for music.
                            • #89
                              • #90
                                a long post , you found the remember me button ?
                                i understand and thats what i'm trying to do . i don't think i was that far off at all besides the fact that i was assuming a 89db woofer when in fact it's closer 83db .
                                my woofer is 2.4 mH , 40uF (s)
                                mid : 1.8r , 12uF ,2mH (s) , 30uF , .5mH , (4.7uF-3.3r) (s) .1mH
                                tweet : 5r , 3.3uF , .2mH (s) , 6.8uF , .5mH (s)
                                **** (s) denotes shunt ..
                                Paper Towers
                                Boombox
