Next ?
  • Originally posted by rpb View Post
    I see something weird with your sim graph. On post #62, the mid is 6dB below the sum. I assumed that sim showed one mid, although two would be 6dB higher. In these new sims, the mid touches the sum. The little icon that indicates a mid looks different on the two sims. One has something dark on it. Is it possible that it's turned off or something? Obviously I'm not familiar with xsim.
    i noticed both of those as well and not sure why . no idea where or what that lil grey box is either .
    Paper Towers
    RS180P/28F surrounds
    Boombox
    • Originally posted by filmslayer View Post
      Makes my mid sim look too low, but it's not. My sim in post 114. Raise the mid 6dB, and the sum will improve dramatically.
      Do you save sims? If so, select one where the mid is not dark, and re-enter values of my sim. Not that it matters. The newer adjusted files change a lot anyway. Do you suppose that dark thing is maybe a way to mute a driver in the sim???
      We'll get there eventually.
      • when i started this one i never would have thought the RS225 would be the weak link .
        Paper Towers
        Boombox
          Do you mean sensitivity?
          PE data shows the RS225 to be 87dB at 100hz. Subtract 6dB for full BSC, and that puts the speaker at 81dB. The mids don't loose much in their pass band to baffle step.
            yeah , sounds good but needs to be turned up quite a bit more than i normally do . all my builds with them before they were in multibles ...
            with your files and +6db added i also added back the -6db from the 225 ...
            Paper Towers
            Boombox
              the grey thing on the mid indicates it is muted, right click it and unmute.
              • Originally posted by joe_bernardi43 View Post
                Voice of Gomer Pyle....Thank you, thank you, thank you!
                  thank you .
                  Paper Towers
                  Boombox
                  • no problem
                    • Ok, so now we know, and have closer files. My sim used the 7.1mH, 40uf for a x-over around 400 or so. The mid has a pesky peak using my modified file, but I guessed at the height, and only used one driver. Your mtm is probably smoother than my file shows. I'm going to call it a night, and watch a little Netflix.
                      • I see you are using mustard glue. My favorite
                        Just another hobbyiest.
                          btw , these are PE factory files for the RS225 and DS90 and traced factory for the Neo . i can attach the Neo file if anyone wants to play along .
                          Did you add in the baffle response?
                          John H
                          • no John , just traced . baffle is 11 x 36 ....
                            Paper Towers
                            Boombox
                            • Originally posted by jhollander View Post
                              The files posted in post 116 and 117 were modified for a baffle. I guessed at some dimensions. I think I used 10" x 40" and 18" off the floor for the woofer, and 29" for the mid. I know there's two, I just wanted something in the ballpark.
                              • Comment
