Removing sticky stuff from veneer
  • Removing sticky stuff from veneer
    I have some sticky residue on some speakers from small pads that were on the bottom. What is a safe product to use that will remove the residue without harming the wood? The finish appears to be a simple was rather than a shiny poly or similar.
    I've used baby oil to remove the glue residue left behind from contact paper on a "vinyl" veneer. Worked great after other solvents didn't (alcohol, WD40, acetone, etc.). Always check in a inconspicuous area first.
      Interesting. Good idea.
        There is a product made specifically for this, goo be gone.
        craigk
          WD40
          spray cooking oil
          John H
            if you can handle the stench , we use ammonia to remove pressure sensitive adhesive . though i've never tried it on wood .
            Paper Towers
            RS180P/28F surrounds
            Boombox
              I might be a little shy about use of Ammonia on them but I am not sure if it would be OK
                when we have to remove old window film or vinyl lettering it'a what we use . you could try it in a small un-seen place ... it do stink !
                Paper Towers
                Boombox
                  Goo B gone
                  General rule is to use the least volatile solvent that works
                  Tangband W6-sub
