Any other not so obvious benefits using 2 identical drivers
  • Any other not so obvious benefits using 2 identical drivers
    So aside from gaining 3db wiring 2 drivers in parallel what else do you gain besides 3db and larger box
    Just another hobbyiest.
    You gain 6db in parallel. You also gain lower distortion, higher total output capability, and more come area go more impact.
    -Kerry
    www.pursuitofperfectsound.com
      Where voltage sensitivity and maximum output is concerned you get 6dB, not 3dB. Using two smaller vertically aligned drivers rather than one larger driver with the same Vd also gets you wider horizontal dispersion and potentially better high frequency extension as well.
      www.billfitzmaurice.com
        I asked the same a few years ago, and the experts said:
        gain 3 dB with the doubled surface area
        gain 3 dB with the halved impedance.
        Speaker Building 201 covers a bunch of different configurations with multiple woofers. Highly recommended.
        Tangband W6-sub
          My two driver are 4ohm. So that would put me at 2 ohm. So series might be the way igo. But i only get 3db gain in series correct. And 8ohm instead
            You will gain 3db in db/watt. You will be at the same level db/volt. So it will seem the same loudness as one driver, but at 8 ohms you can turn up the 'volume' higher without bothering your amp(less distortion from less cone excursion, and less current gives less distortion with most amps).
            Run 2 ohms only with amps with big power supplies and heatsinks- test, don't trust ratings.
              With two identical drivers, you also help fill in the floor bounce notch, somewhat. Three would be even better in this regards.
