Deconstructing an Elac
  • Deconstructing an Elac
    https://www.youtube.com/watch?v=oWWXH8yLEQI
    Crutchfield Tech does something unusual; Just an FYI
    “Never ask people about your work.”
    ― Ayn Rand, The Fountainhead
    Okay, what is the benefit of that alignment?
      The passive radiator and the air volume behind it will act as an acoustic low pass trapping the port noise and any higher order distortion products inside the box whole still allowing a forth order roll off on the bottom.
        Damn that speaker cost $1249.99 each.
            I wonder if you could diy something like that with a dayton classic 10 with its motor pulled off? Regular passives would be to heavy.
              It would get rid of the port noise bit it wouldn't trap distortions coming from the woofer itself. The people who build synergy horns talk about that as one of the advantages of using acoustic bandpass arrangements.
                Another advantage is that the light weight passive won't create the same vibration that a conventional heavy passive would. That's actually a very cool design.
                  ok... THAT was cool! Wish they had some detailed shots of the XO board. I'd like to see what kind of components they use. Nice to see some of the construction techniques they use are similar to those we use in our DIY speakers. Nothing too fancy going on in there, just good drivers, simple construction, and I assume a rockin XO design.
                  The Super Bees - Garage 2 way
                    Crazy design! Lots of chokes on that XO...
                    Guess xmax's age.
                      And to think I was a little worried about 3 chokes on the same board I did.
                        Its just a bandpass, with the passive radiator providing the benefits of a passive radiator.
                          +1, a series tuned 6th order bandpass. The main advantage of a PR rather than port in the front chamber is the same as with any PR, it allows a smaller chamber, as a PR takes up less room than a port. It might not look like it, but it's a close cousin to the Karlson Speaker.
                          www.billfitzmaurice.com
                              Reminds me of the Bose accoustimass base module but instead of using a passive radiator it used a port....I have always wanted to try it with a passive radiator, some one beat me to it. LOL
