Ultimax 8
  • #16
    I have an old pre amp with lfe or I would need another amp for the subs so I could use a high lvl input. I was hoping to use the lfe and both channels to simplify things.
    • #17
      That will work, see my note above. You don't need to bridge.
      John H
      • #18
        With some suggesting the Ultimax, while sounding good sealed, state that there are better subs for music. So I'm left wondering if the Reference Series Subwoofer drivers are maybe better musically than the Ultimax, although most likely not as robust.
        • #19
          I was wondering that myself. As far as the motor goes, the RS have a triple shorted motor (I'm guessing pole cap, upper & lower rings?), where as the Ultimax only has a copper sleeve-cap? Of course that is only one part of the whole equation as the linearity of the BL field and the suspension Kms adds up to quite a bit as well.
          • #20
            I thought about going with the RS line at first but it looked like the box was going to be a lot bigger especially the hf version. Then I saw that the ultimax went on sale and thought since it's for both music and ht I would try that instead, it seems to do both well but time will tell.
            • #21
              While I haven't tried an Ultimax, I use an RSS390HF in a sealed box as a woofer for music, up to 150Hz crossover. The bass is very clean and tight, comparable to my good headphones.
              Francis
              • #22
                Yep, the larger Vas figures aren't fully "countered" by the lower Qts values unfortunately, so you end up with a larger overall box for the flatter alignments. With the Ultimax, the balance owed is paid with the lower overall sensitivity due to the lower Vas directly resulting in smaller enclosure sizes. Rest assured, the 8" Ultimax's do a great job for music in a good passive radiator loaded enclosure. With param EQ via DSP, I'm getting flat, in-room response with them down to 23Hz, in what looks to be about 0.5 ft³ internal enclosure volume with two PR's in each box.
                • #23
                  That's small and low!! Maybe I'll have to take a serious look at getting some passive radiators.
                  • #24
                    Of course this kind of setup has very low sensitivity in the lowest octave and has to be made up [via DSP] with lots of clean amplifier power with very high headroom. Lucky for me, each one has a Peavey CS800X strapped to it. ;)
                    • #25
                      Well you don't get something for nothing.
                      • #26
                        Originally posted by wogg View Post
                        I have a plan for those, a 15x14x19" box tuned to 27Hz using a 3" precision port. F3 of 23Hz, 106dB output with no exertion issues up to rated 300W.
                        I have to keep that in mind. I was looking at the Ultimax 8 as well. Do you have a write up about the sub? Thx
                        • #27
                          Nope, it's all theory right now. My ideal system would be a pair of stand 2 or 3 ways with a pair of small subs crossed with DSP for room corrections. While dreaming of having a place to put that system and then making the system itself, I've modeled a ton of small subs that included that Ulitmax driver at the higher end of the costs.
                          Wogg Music
                          • #28
                            https://www.parts-express.com/dayton...-dsp--300-8010
                            Do you guys think this would be a good match to my 8in ultimax or should I get something with more headroom? Was thinking of keeping it sealed to keep cost down.
                            • #29
                              I personally would go with more headroom.
                              I would still go with PR if it were me...With as low as the sensitivity is, it needs all the help it can get, IMO.....A single Earthquake 10" PR would do just fine, as they're capable of a lot of excursion....Right now they're $20 cheaper than they normally would be on Amazon Prime...I just bought 8....
                              • #30
                                Price does't look too bad. Are you going to build your PR setup soon?
