Any experience with Dayton RS225-8?
  • Any experience with Dayton RS225-8?
    nd order at 600 Hz to Scan-Speak 13M/8640
    I think I can reach abt 30 litres CB when flushmount the baffle and reduce the mid-cabinet size
    Regards//lasse
Name:	RFL-DVC sidewiew.JPG
ID:	1365189 Click image for larger version
Name:	RFL-DVC frontwiew.JPG
    Perry Mason talking to his dentist:
    LR2 @ 600 would be no problem . in my current project i'm doing LR2 @ 900 ...
    Paper Towers
    RS180P/28F surrounds
    Boombox
      Nice,
      Is this a good sounding woofer, in your opinion?
        yes . nice bang for the buck . i have 2 in my center channel and here is current project http://techtalk.parts-express.com/fo...m/1360812-next
        Paper Towers
        Boombox
          I am considering a stepped baffle, making the mid and the woofer coming out 19 mm and crossing tw/mid 1st order at 3000 Hz.
          Regards// Lasse
            It's a fabulous driver. 30L is a bit on the small side but will work tuned to 30hz. That would be a 2" diameter vent 7.3" long with one flared end. I've used them higher than 600, but 600 seems to be ideal for that driver.
              Hello
              I haven't heard this driver, but Curt Campbell uses it in several of his designs - so it must be good!
              Looks really nice, too.
              Geoff
                Did a re-fit of an old vintage 2-way with the RS225-8 and the RS28F crossed at around 1500Hz. Stunned at how good they sounded. Great woofer.
                  I have a pair of the paper-cone versions in a 78L cabinet tuned to 32 Hz and they sound absolutely wonderful. They are crossed a littler lower though, right around 180 Hz to an RS180P-4. I imagine the aluminum version being comparable in performance. But they can put out some serious bass, not subwoofer bass, but nice, clean, well-defined low end, perfect for music. I'm not sure where the upper limit on these would be though, since I don't use them up very high, but for a bass driver they are quite nice.
                    Any details on that?
                      I'll see if I can have my buddy Otto send me some pics of the final product, but picture sparkly black grill cloth over dark walnut boxes and you'll have a good idea. Lots of diffraction to deal with in the enclosure that shows up in the tweeter response plot.
                      We wound up with LR4 on tweeter and woofer. 12uF and 2.2 Ohm in series with the tweeter (+) and .25mH shunt
                      2.2mH, 18uF + 1.5 Ohm shunt, and .8mH input to the woofer (+)
Name:	von retro.jpg
                        [ATTACH=CONFIG]n1365311[/ATTACH]
                        Thanks. I was thinking of using the RS-225 in my large Advent cabs with missing woofers and good original tweeters. But I was having problems crossing circa 1500 Hz, dealing with the RS-225 breakup. In the meantime, added some MCM 12" woofers and a cap/resistor to make the woofer LP 2nd order.
                          I crossed a parallel pair over to the RS52, 2nd order (sort of... it's a Duelund crossover) at around 600 hz in my Trilliums. I can't recall how I have them tuned, but the cabinets are around 75 liters. I have a few recordings that they can't keep up with, such as the Mercury Living Presence Firebird and the Reference Recordings Fiesta, but those really require a subwoofer. I'm completely happy with them.
                            Like Pete, I paired an RS225-8 with an RS28F in my RS duets, a floor-standing ML-TL. "Markk" did the crossover design, a notched, Cauer-Elliptic having quasi-8th-order roll-offs at 1400 Hz. The system tuning frequency was 29 Hz and the predicted anechoic f3 was 32 Hz.
                            Paul
Name:	Cabinet front without grille.jpg
                              Hello,
                              and thanks for all the feedback.
                              I am now convinced that the RS225-8 is the right woofer for me.
                              Now, you cunning DIY-ers, used to this woofer, what do you think?
                              I have in my inventory a pair of Dayton RS52AN-8 mids. Is this a better choise than the existing SS 13M/8640, given the new woofers in the system you can see on the pictures in the OP?
                              Regards//lasse
