VW Touareg speakers
  • VW Touareg speakers
    I realize the site is mainly speaker building but I'm looking for feedback regarding the components I've selected for my 2005 VW Touareg. My goal is to improve the sound overall and dedicate subwoofers for the low end without installing one in the cargo area. The factory head unit will be replaced with aftermarket to utilize the RCA outputs and bypass my OEM amplifier with a Soundstream ST4.1000D amplifier. It's rated for 90Wx4 RMS @ 4ohms and is small enough to fit in the storage drawer under the front passenger seat. I'll use two channels for the front stage and bridge the other two channels to 250W for the subwoofers. The Touareg has odd size (for me anyway) speakers...8" in the lower doors, 3" in the upper doors, and tweeters in the front door near the A-pillar (no tweeters in the rear doors). I'd like to run a 3-way configuration in the front doors, 8" subwoofers in the rear doors, and power the 3" in the rear doors off the head unit. Does anyone see any faults with what I have chosen?
    Front tweeter - https://www.parts-express.com/peerle...-ohm--264-1528 with https://www.parts-express.com/5-khz-...sover--266-472
    Front midrange - https://www.parts-express.com/dayton...river--295-154 with https://www.parts-express.com/parts-...sover--266-452
    Front woofer - https://www.parts-express.com/dayton...eaker--295-309 with https://www.parts-express.com/800-hz...sover--266-448
    Rear midrange - https://www.parts-express.com/dayton...river--295-154 with https://www.parts-express.com/speake...50-hz--266-200
    Rear door subwoofer - https://www.parts-express.com/peerle...ofer--264-1102
    Thoughts/suggestions?
    Thanks!
    If you want to run a three way system up front you would be better off going to a fully active system with dsp which will make it much easier to tune. If you don't want to go down that road then I would look for a good 6" 2 way system for the front doors. The problem with that woofer is it is not designed to run open baffle in a car door, unless you plan to build a sealed enclosure for it. Same with the rear sub you have picked - it needs .7cf of airspace for a sealed enclosure and will only be tuned to 60hz or so. That little amp probably wouldn't like running 6 speakers off the two front channels without a proper 3 way crossover either - could be too low of an impedance load for it.
    See my projects on Instagram and Facebook
      Since each driver would be in its own spectrum would the amp see 4ohms since thereís no overlap? Sent from my iPhone using Tapatalk
        I didn't notice that the mid x-over was a band pass - it might work then. Might be worth putting the three drivers zma and frd files into a crossover design program and see what kind of impedance values you would get with the crossover boards you have picked.
        Edit - I added the files into Xsim quickly - looks like it would be pretty much a 2 ohm load. Bear in mind this is just a quick sim and might not be 100% accurate - but should be close.
          A 2ohm load wouldnít be a deal breaker. I havenít made any purchases and am flexible on the amp. Now if I could find a suitable subwoofer. Iíd prefer to find a raw driver if for no other reason than to say all of the speakers are a non brand car audio brand name. To see if I can configure a decent sounding system utilizing all of the factory speaker locations. Iím sure using a DSP and making custom crossovers would be the best options, though. My budget isnít there for a DSP and my skills definitely arenít there to make crossovers....someday, hopefully. Sent from my iPhone using Tapatalk
            I had read many car stereo guys praise the Silver Flute woofers on the web over the years. I bought the 6.5s last summer, along with some tiny Peerless OC25SC65-04 tweeters. I took near-field measurements, modeled the crossovers, and added some sound deadening to the doors. IMO, those woofers do live up to the hype. They are built VERY well for a $30 woofer.
              Thank you for the recommendation! I will look into them. Sent from my iPhone using Tapatalk
