My first build - Classix 2.5
    Yes. Looks good to me.
  • Jakes_dad
    Your drawing looks good.
    AFA the physical layout goes, even though you've got the 2 largest coils oriented properly (90* angles), I'd (personally) feel better with some more space between them. Even if you could slide the 2 big caps to the left, and drop the 0.90mH in THERE - which would probably then make it better for the little coil to stand up (again, 90* thing).
    Chris,
    Maybe I didn't drink enough coffee this morning, but I am having a hard time visualizing what you mean by "slide the 2 big caps to the left, and drop the 0.90mH in THERE - which would probably then make it better for the little coil to stand up".
    I revised the drawing to move the 2.0mh coil to the other end of the board, would that be OK?
  • Geoff Millar
    Originally posted by Jakes_dad View Post
    First I want to thank everyone for helping me out so far.
    I have also attached a drawing of my crossover layout and I would appreciate it if anyone could check it for me.
    Thanks again,
    Richard
    The short answer is 'I don't know' - this is because I have great difficulty reading those sorts of drawings.
    What I do is physically get the parts, and in this case, Paul's diagram, and lay them out on a large piece of paper so that they look like his circuit diagram. I then write the inputs, plus and minus etc on the paper next to the wires, eg 'woofer out +".
    That way, I can't really go wrong. I can then shrink the layout to fit the boards, which I make from Masonite. It means that I have to split the input + and - from the binding post into two but that's OK.
    I make two boards, because I'm an electronics illiterate: one for the high pass and one for the low pass. It looks messy, sloppy and unprofessional, but they're out of sight anyway and it might make troubleshooting easier.
    Hope this helps but sorry I can't answer your question directly
    Geoff
  • Jakes_dad
    Thanks again,
    Richard
  • Jeff F.
    Jeff,
    I am going to use machine screws and T nuts to attach the drivers and I will get those locally. I have some speaker wire for wiring inside the cabinets. I am going to use this solder if you think it will work OK.
    That solder should work fine.
  • Jakes_dad
    Yeah I caught that one after I made that first post.
    This is the one I was going to order - PE 027-360.
    100uF 100V Electrolytic Non-Polarized Crossover Capacitor
    Sure. What'cha doin' w/that tiny 0.10uF cap?
    PE DOES carry cheaper 10w resistors. I like 'em 'cause they don't have the gold plating on the leads (which tends to break and fall off when bent).
  • Jakes_dad
    Geoff,
    I have added the binding posts to my cart. I think I have enough egg crate foam and polyfill left over from another non-speaker project that I did, so I should be OK on those.
    Thanks for the tip on the tweeter, I hadn't noticed that before.
    What about the crossover components, do those look like all of the correct parts and pieces?
    Thanks,
    Richard
  • Jakes_dad
    Jeff,
  • Geoff Millar
    Do you have binding posts and either polyfill or Acoustastuff? Also a swear box for those "uh oh" moments.
    These should sound great!
    And when you're connecting things up, remember that the tweeters are connected with reverse polarity; good luck with the build
    Geoff
  • Jeff F.
    Screws for driver mounting, cabinet feet, wire, solder? Looks like everything is there.
  • Jakes_dad
    started a topic My first build - Classix 2.5
    I am starting my first build of the Classix 2.5 and was wondering if someone can check my cart contents for me.
    Any help would be greatly appreciated.
