Dayton 18 inch subwoofers
  • Dayton 18 inch subwoofers
    I am going to be purchasing a couple 18 inch Dayton subs soon for a car stereo install. I have enough room to give each subwoofer 3 cubic feet, I definitely want to run them sealed for tighter snappy bass. Available power will be just over 1150 watts each, at a 2 or 4 ohm load.
    I'm certain they both will pack a lot of punch in my small SUV. My question(s) specifically..
    Which is more musical in same approximate size sealed enclosure. This is a mid size SUV
    The ultimax 18. Or the reference HO 18
    Pros, cons of each? Which ones going to play cleaner from 10-15hz to 70-90hz ? Power isn't an issue so not interested in ported box, I'll take the tighter snappier bass of a sealed box
    I can easily do 3 cubic feet per sub (single box with two sealed chambers) maybe 3.5 cubic feet tops?
    I'm building a 4 way active system with dual subwoofers. I know this is overkill, but excess is best.
    Go to linearteam.org and download WinISD (it's free). Learn how to model boxes. You'll see that the UM18 in 6 sealed/stuffed cf will hit 30Hz, deeper in car.
    NEITHER of those subs will particularly like a 3cf box. If you're set on a pair, maybe dual 15s would work??
      WinIDS http://www.linearteam.org/
      UniBox http://audio.claub.net/software/kougaard/ubmodel.html It runs in excel.
      UniBox how to written by greywarden http://techtalk.parts-express.com/forum/tech-talk-forum/52689-unibox-for-newbies?233564-Unibox-for-Newbies=&highlight=Unibox
      Seriously, it's easy to do and you'll have fun playing around with all the different combinations. Not saying these alignments are optimum, but it only took a couple minutes to enter the data into UniBox. It makes it easy to see what happens as parameters change; Dayton um18-22 and um15.
        Thanks guys. Hmm maybe one will work out better. I actually have enough room for almost 9 cubic feet but it would not be easily removed and would sacrifice room for tow strap, and miscelanious things in the cargo area
          Originally posted by Bill C View Post
          .. a couple 18 inch Dayton subs soon for a car stereo install....
          ( to think I use (2) 18" in 22,000 cu ft room )
            I have waited 25 years to have a system like this. Divorced, kid is grown, oh yes, I will have it! Bwahahahaha
