Dayton SPA250 vs Yung SD300 - Interesting Results
  • Dayton SPA250 vs Yung SD300 - Interesting Results
    This guy runs amp "dyno" tests on his YouTube channel. Usually he's testing car audio amps, but he tested and compared the Dayton SPA250 and the Yung SD300 amps. I found the results to be interesting...
    He also tested a few of the Behringer iNuke amps in another video.
    I'll save you guys the trouble of actually watching this.
Name:	Subwoofer Plate Amps_ Dayton SPA250 vs Yung SD300 Tested - YouTube 2018-03-08 11_13_52.png
      Thanks! I'm not a fan of sneaking YouTube video time during work hours. (somehow that's worse than lurking and posting in my mind)
      Not sure what their measurement method was for the Dynamic RMS power... a short burst of 40Hz? That seems to indicate more capacitance in the power supply. The SPA250 likely has an unregulated linear transformer supply, which tends to sag under continuous load but when backed by a good amount of filter capacitance can give you large amounts of short term peak power. Typical class D amps are powered by switching supplies, which lack that capacitance for filtering and won't push out short term peaks above their rated power.
      There's a very good reason switching supplies don't need the capacitance. For a linear supply with a bridge rectifier, you're filtering out 120Hz ripple. A switching supply runs in the 10's of kHz for switching frequency, so the filter requires far less capacitance to remove the ripple.
      Wogg Music
      Published projects: PPA100 Bass Guitar Amp, ISO El-Cheapo Sub, Indy 8 2.1 powered sub, MicroSat
        Behringer iNuke 6000 tested here, it is actually about 2KW/ch not 3K:
        https://www.youtube.com/watch?v=73Z2fNcGGDI
          Lepai LP1601S:
          https://www.youtube.com/watch?v=iO-MVAnA9f4
            Vintage NAD 2200 +6dB dynamic headroom works:
            https://www.youtube.com/watch?v=CA58...wIVcfTT3BEWaFD
              Vintage Proton D1200 amp also with +6dB dynamic headroom and it works:
              https://www.youtube.com/watch?v=DL8R...wIVcfTT3BEWaFD
              Nice internal build and meters.
