What makes a good Rock n Roll speaker?
  • Originally posted by Sydney View Post
    More like an example of the realistic compromises ( Hoffman's Law etc ) necessary when using relatively small (6.5") drivers ( low Sd ) tuned low ( 28Hz ). Excursion doesn't necessarily replace radiating surface area in air movement ( acoustic impedance favors larger surface area ).
    Sydney, if you'd bother to slow down and look for a second, you'd realize that the pair of 7" woofers has more surface area than an 8" woofer, so your reasoning doesn't really hold.
    The shape of the response is due to the tuning of the enclosure. cjd chose a low tuning to give a more gradual roll off to the bass performance, knowing him, so that it better complimented a typical listening room.
    • Originally posted by Montana1 View Post
      Could it be that this measurement was gated? Therefore everything below say 200 hz is not valid. I would think duel Anarchy woofers would have much better low end extension then what is shown in that graph.
      Depending on the enclosure tuning, the response shape can vary quite a bit. But I'd wager that the posted response plots aren't really accurate below 200Hz.
      Here's a guess at the tuning in the Apollo MTM vs a possible 28Hz tuned Ansonica enclosure. Both of these responses are usable but will definitely flavor the sound of the lower octaves. Factor in a typical room and the room-gain curve, and the larger enclosure with the lower tuning would probably offer truly deeper bass response at the penalty of a larger enclosure.
Name:	Box tuning comparison.jpg
      • Originally posted by Pete Schumacher View Post
        Sydney, if you'd bother to slow down and look for a second, ...
        The opinion I stated was in regard to a 6.5" driver ( posts #99 - 101 ) .
        I have read the Vance D test on the W06-017R 6.5:" driver ( originally posted in V.C. ) . His report was objective and comprehensive.
        The referenced design takes a driver with 46fs down to 28hz with a EBS tuning.
        While it is a good driver, it is still subject to Physics ( actually SD .0129 radiating surface is closer to 5" diameter each ) .
        I would prefer you ignore my posts rather than this 1st person condescension.
        • Sydney, again you're ignoring the FACT that there are two woofers in the design, with a combined surface area greater than an 8" woofer.
          262cm^2 for dual Anarchy or 258cm^2 for your cited Sd.
          225cm^2 for a single RS225
          Dual 7s have more area than the venerable RS225 8" woofer. Not only that, they have twice the total available linear displacement.
          Now, does physics apply or doesn't it? Or do you insist that a line array of 10 7" woofers won't have the surface area to properly render bass frequencies simply because of their diameter?
          • No I did not ignore that there are 2 drivers and their combined Sd.
            A little larger than a 8" being asked to provide reasonable reproduction of high demand source material down to 28Hz. (wow)
            And a design that presumes room gain in a "typical room" ( not sure what that really means ). and
            ( no thanks )
            Perhaps it comes down to what comprises personal requirements. Room size, SPL, Acceptable level of performance.
            I detect than there is a defensive posture being taken because the designer is a 'friend'.
            While subjectively some liked the design, it does not mean it would be satisfactory for all.
            Certainly not for my purposes, nor most my acquaintances ( and no we don't listen at deafening levels ) .
            In a related thread I posted a John Eargle article on design of Studio Monitors. The implementation philosophy contained there is in line with my take on the criteria necessary to address the R&R task.
            • What makes a good Rock n Roll speaker?
              craigk
              • no beer while at the mixing board thanks
                • Humulus lupulus has a cladistic cousin that's usually consumed dry. You're never going to recreate the sensory experience of a live concert without its smell.
                    And a design that presumes room gain in a "typical room" ( not sure what that really means ). and ( no thanks )
                    If you dont know what room gain is its easy to look up. Boundary reinforcement plays into the effect.
                    Unlike you, I’ve actually heard two different implementations of designs employing dual Anarchy woofers. It’s not because I know cjd that I defend his design. It’s because I actually listened to it.
                    Having done multiple designs using everything up to 21” woofers, I can say without reservation that having a quartet of those woofers in my 15x18 living room with cathedral ceiling and only 120W/ch pushing them, the experience is quite visceral. And they can handle even more power if average listening SPL at 105dB isn’t enough.
                    I’d wager a six pack of your choice that Ansonica would bring a smile to all of you at the levels you listen.
                    • How could I forget that ONLY your listening experience is relevant and applicable to ALL other persons and situations.
                      PLEASE put me on your ignore list - Thanks
                        So, we are supposed to take the advice of someone who’s never heard a speaker say it can’t do something that someone else who’s actually heard them says it can? Or that a speaker that doesn’t use pro sound woofers and compression horn tweeters simply can’t play rock and roll?
                        Hahahahahaha.
                        You can choose to ignore me too.
                        • This is all my fault.
                          • When entered into bass box pro, 4 Anarchy drivers will do 120dB down to 32hz.
                            That is astounding performance THE END.
                            Guess xmax's age.
                            • https://www.youtube.com/watch?v=v6yWJzCg2y8 King kong aint got Dee Bee on me..LMAO
                                [ATTACH=CONFIG]n1372884[/ATTACH]
                                Hi Pete,
                                I have existing cabs that are around 40 liters net volume and do appear to be a good candidate for MTM's using these Anarchy 7" woofers. I have attached a screenshot from Unibox if you don't mind taking a look at to make sure I'm on the right track volume/ tuning frequency. Also, since this build is not likely to take place until next year, what is the long term availability of these Anarchy woofers?
                                Best Regards,
                                Rich
