MIT Cable
  • MIT Cable
    MIT cable surgery. Ever wonder what was in that box? Me too.
    craigk
    Trying to get the circuit board out. More info as I dig deeper.
    craigk
      A circuit board! You must have a fancy model! Expect to find a resistor, maybe a cap or even an inductor in there...I'd expect that the filter is in place so that you can actually tell the difference when you swap this cable from a standard lamp cord. Different = better if you are a marketeer. Imagine if that filter wasn't in place, and you swapped the fancy cable for a lamp cord, you may not be nearly as impressed since they'll sound about the same.
        There's a device I'd like to sell you, with this you can make any cable sound like your favourite hifi audiophile cable, and the cost is a fraction at only $999.99.
          These MIT and "Transparent" speaker wires were popular with Wilson Audio's earlier
          stuff with that Focal tweeter with the huge spike around 20K. This is one of the reasons I don't
          deal with HiFi people too much, fixing problems with other problems...
          Guess xmax's age.
            [ATTACH=CONFIG]n1371510[/ATTACH]
            These were free. I never did like them.I actually thought they were dull on the top end. Mids and bass were alright, nothing special.
            craigk
              I am sure your Walmart lamp cords sound just fine, probably matches the rest or your system just perfect.
              craigk
                And still somehow managed to look better than that ball of wax that you're unravelling.
                  It may be of some interest to run an impedance sweep of that "cable" with just an 8 ohm resistor tied to the end. Something that technical might be over your head though.
                    This makes no sense what so ever this was onside a bok v overed up. Have you never seen MIT cable ?
                    craigk
                      As soon as I finish upgrading my cd player's power supply to a battery system and changing the clock, and doing away with the analogue out and changing it to transformers, I will see if I can handle your project.
                      craigk
                        Its all Coat hanger wire these days boys ! Don't you know all the cool kids are using it now!
                          Yes, always wondered what was in the box. IMO, they sounded wonderful on the Spectral/MIT 2c3d system driving the Avalon Acoustics whether it was the digital front end, or Merrill's Stable Table. The same system with the Von Schweikert vr4's wasn't as impressive.
                            "doing away with the analogue out and changing it to transformers" To most this sounds like a oxymoron, perhaps you could
                            shed some light for "most".
                            Guess xmax's age.
                              Ugh, on any other audio forum, you would have a dozen guys singing the praises of $1,000 speaker cables......................
