Introducing the New RST Tweeters From Dayton Audio
  • #46
    Hey Pete and Erich,
    I just got a pair of RST-A and a pair of RST-F, and tried them on the SEOS-8. The grill diameter of these new tweeters is much larger than the old ones so there's no way to fit them flush against the back plate of the waveguide. I guess Erich is going to have to design new ones.
    Hong
    LM4780 Parallel Chipamp
    Sonata Soundbar Project
    • #47
      Good to know, thanks for checking the fit Hong
      • #48
        If you remove the grill will the surround clear with some mods for mounting?*
        Guess xmax's age.
        • #49
          That's what I'm going to do next, but as the opening of the tweeter is much larger than that of the wg, you're not going to have good results. Shaving the back of the wg to create a smooth transition between the tweeter and the wg is the only solution, but that will require some special tools which I don't have.
          • #50
            I really, really, really wish PE would sell a waveguide for the RS tweeters. I find it incredible how few easily available waveguides there are for DIYers that don't require experimentation and modification of the waveguide, transducer or both.*
            • #51
              I recently bored out a PRV WG with a big round-over router bit by using as a drill bit, worked great.*
              Guess xmax's age.
              • #52
                I have the new tweeters on hand and my next batch of 3D printed waveguides will include some for them. I see the fabric dome also has a phase shield? Interesting.
                ~Brandon
                Soma Sonus
                DriverVault
                • #53
                  Phase shield... Ya mean that little disc of plastic just underneath the top of the grille? I saw that, and recognized it from other high quality designs, but I haven't looked up an explanation of exactly what's going on (physics-wise). So far I've just assumed "good thing" and have started brainstorming designs.
                  The Super Bees - Garage 2 way
                  • #54
                    Phase shields are used because tweeters are domes, and not flat. Sound propagating from the center of the dome would arrive sooner than sound arriving from the edges of the dome. Not a big deal with lower frequencies, but here the wavelengths are sufficiently short that you'd have phase cancellations and ragged response. So you cover part of the dome with the phase shield.
                    It's a little unusual here because normally fabric domes have enough internal damping or are coated in such a way that sound propagates more uniformly. It's usually more of a "metal" problem.
                    nothing can stop me now
                    • #55
                      Thanks bud! That makes sense. I learn something new every day
                      • #56
                        You only need a router table, a jig, and the ability to take good measurements(not acoustic :D).
                        http://www.diy-ny.com/
                        • #57
                          Soft domes are into break up at those frequencies so don't vibrate like pistons and don't have the path length cancellation issues.* The damping helps keep the response in control while break up is having its good ol time
                          • #58
                            There is only one thng worse that being talked about, not being talked about. Oscar Wilde.
                            i would settle for this tweeter not being talked about anymore unless it is about how it sounds and measures acoustically. Anybody?
                            • #59
                              fred, we're just killing time until someone starts posting results, how's the weather in texas?
                              John H
                              • #60
                                Are you telling me to go outside and play? I took my dog for a walk this morning went out in the back with her a couple of times. It may be warm enough to go swimming pretty soon. She has been several times this spring. She gets hot after her walk or her sun bathing and jumps in the pool to cool off.
