So I was breaking in a brand new Ultimax I just received.* Naturally it was a 20Hz test tone to get the excursion flowing.* After a while I heard a ticking noise, and found this:* the epoxy/CA/whatever at the triple joint was allowed to roll-over into the 1st trough of the surround:
This is the case on both sides where the tinsel leads are.* This is not how my other (used) Ultimax is, and thus works just fine.* The noise was the adhesive that had lifted off the trough of the spider (at all 4 points) was smacking the spider, like 4 little feet tapping as the assembly traversed from peak-to-peak.* Hopefully you can see what I mean in this picture:
I don't suspect it would be a world-ending problem as I'll never run anything below 30ish Hz, but still, I know for a fact it shouldn't be that way and I can only suspect that there is a small chance that the section that has lifted out of the trough might take the rest of the joint out with it.* What would you do?* I know it has a 5yr warranty, so that does put me somewhat at ease.
