Your experience with modifying raw loudspeaker drivers and the results.
  • #16
    I'm not sure this qualifies as an improvement, but certainly as a modification. I've added bucking magnets to some drivers.
    • #17
      what does that do ?*
      • #18
        From PartsExpress:
        These fully charged ferrite donut magnets have many uses. Can be used to add shielding to small woofers, midranges or tweeters, which allows speaker to be placed in close proximity of picture tubes and computer monitors. Commonly referred to as bucking or cancellation magnets. Simply attach the magnet (in reverse polarity) to the speaker back plate using epoxy or cyanoacrylate (super glue). As a general rule, the bucking magnet should be approximately 1/2 to 2/3 the size of the driver magnet. Limited availability
        *And also, as I understand it, bucking magnets push a bit more magnetic force into the gap, which causes a slight increase in efficiency.
        • #19
          Ratch Higgins showed me some before and after measurements of full range paper cone drivers that had been coated. There was a smoothing of the frequency response.
          • #20
            Yea, in the 80s I used some Pioneer A11ec80-02F full range drivers that were paper cone and put them on an old turntable and used some white liquid that Mark from Meniscus Audio had showed me at his shop. Back then I lived in Holland Michigan so was only a 20 min drive to his shop, anyway they looked really glossy when dried and he told me it would stiffen the cone. kinda fun too.
            • #21
              "I'm not sure this qualifies as an improvement, but certainly as a modification. I've added bucking magnets to some drivers."
              "What does that do?"
              The bucking magnet reduces the stray magnetic field (useful when TV's were cathode ray tubes), strengthens the magnetic field in the voice coil gap, and lowers the Qts.
              When installing, the bucking magnet magnetic field initially pushes away from the driver magnet. Then when the magnets are about 1/4" apart, they attract strongly, so watch your finger tips.
              • #22
                I've seen improvements with some applications, but also some made worse, much worse, especially smaller drivers like a midrange. Peaks were reduced but the overall response was more ragged. It also reduced the sensitivity. This is added mass after all, so anything more than careful, selected treatment will affect that. On a larger driver, the ratio of original mass vs. after-treatment mass may not be much different, but it's a crap shoot IMO. Surround treatment, when warranted, isn't as problematic.
                dlr
                Dave's Speaker Pages
                • #23
                  • #24
                    304 pages of inspiration. Mods if posting another forum's thread is improper please delete. No harm intended.
                    EnABL Processes - diyAudio
                    • #25
                      Originally posted by djg View Post
                      This hobby is all about happiness. Normal is over rated. And I didn't say "dampening".
                      Yep, if you dampening those steel woofer baskets too much, they'll rust. LOL
                      • #26
                        I don't*like my speakers raw. Medium to well done with a little season. I must be hungry! Off I go to dinner!
                        On the cheap diy. That is my motto - www.hifiposse.com
                        • #27
                          I try not fry my speakers and like the mids warm and the tweeters not too hot....*
