Not seen this topic before. Space back of driver to back of cabinet. Not wall
  • mobius
    If you are concerned with minimizing the reflection of the backwave through the cone, more absorbing insulation can be used as you increase cabinet depth. Types and thickness (ie. depth) of insulation would vary with the frequencies you are trying to attenuate.
  • mattp
    Easy rule of thumb:
    If the pole piece is vented try to allow as much space as the pole vent diameter from the back wall. IE: 1/2" diameter pole vent, space the woofer 1/2" from the cabinet wall. Same rules apply to port tubes.
    If the pole piece is not vented then no, it does not matter how close it is.
    An on-wall speaker should have as shallow a cabinet as possible, to place the null frequency from Allison Effect as high as possible. Ideally the cab would be wide enough so that the baffle step would occur at a low enough frequency that there is no Allison Effect.
  • Not seen this topic before. Space back of driver to back of cabinet. Not wall
    https://hometheaterreview.com/martin...nding-speaker/
    Of course, they have the money custom design drivers. Not sure if stock drivers would work with so little depth. It's why I ask?
