fdieck "sounded like music not loudspeakers !"
  • #16
    Originally posted by fpitas View Post
    ... It really helps to know the DI of the horn vs frequency, to get things sorted out.
    It is an essential element in large Pro Sound applications; such information in the basis of the CFL database - "The CLF (Common Loudspeaker Format) Group was formed for the purpose of defining and maintaining a single, open file format that loudspeaker manufacturers could use to supply data to end users in the professional sound and acoustics community."
    A Horn exceeding a 3 octave bandwidth has always presented "issues".
    • #17
      Lucky for me, Smith, Keele and Eargle from JBL measured the Altec 511 and plotted extensive data in their paper, "Improvements In Monitor Loudspeaker Systems".
Name:	Altec 511B Polar.png
      Francis
      • #18
        Originally posted by dcibel View Post
        *Here's a plot where I did just that. Black is the on-axis, and red is the weighted average. As you can see I have some excess energy in the 2-4kHz range.
        Click image for larger version Name:	weighted average.png Views:	1 Size:	14.1 KB ID:	1375107
        Help me understand this. The 2-4 Khz seems to overlap exactly, so why do you say this is a region of excessive energy?
        • #19
          ...Lucky for me,...
          More like attention to detail.
          Anecdotally - the difference between the cheapest horns and the better ( albeit more expensive ) horns is huge.
          • #20
            On the subject of "sounding like music, not a loudspeaker", I find a slight roll of frequency response appeals to my sense of realism; about 1/2 dB/octave from 200Hz to 10kHz.
            Francis
            • #21
              The black trace is the on-axis response, and the red trace is a weighted average of the on and off-axis response. If the speaker had a constant directivity, you would see a constant slope of the red trace, but we do not, the red trace clearly has a lump around 2-4kHz. A constant slope would indicate a consistent attenuation of all frequencies as you move off-axis. Since the red trace actually overlaps the black, it can be assumed that the amplitude in this frequency rance does not decrease at all off-axis, it is a "wide dispersion" range, hence the excess energy.
              If we look closer at a directivity plot, in fact the speaker does attenuate at the extreme axis, but at the 15-30 degree range it actually increases in output a bit over the on-axis response.
              • #22
                Click image for larger version  Name:	Altec 511B Polar.png Views:	1 Size:	485.5 KB ID:	1375164
                Guess xmax's age.
                • #23
                  Yeah, I damped mine too; cut the vanes and put a bead of 3M 5200 between them, filled the bells with polyurethane, and coated the outside with polyurethane. I have TAD TD-2002s on mine. The imaging and realism are pretty darn good for a horn from 1953...
                  Francis
                  • #24
                    I bet they sound fantastic! I'm working with some TAD 2002 currently.*
                    Guess xmax's age.
                    • #25
                      So, which ones are those?
                      For me, usually a paper coned mid bass driver with tight bass, a minimal breakup peak, and good extension into the midrange. They cover a significant percentage of music all by themselves. Once I find that, the rest is much easier.
                      • #26
                        Here's a set of plots that show the behavior of an 8" 2-way with a 8.5" diameter waveguide, 2" deep with a circular profile crossed at 1KHz.
                        On axis first.
                        The off axis response is exceedingly uniform, and the in-room sound was immersive.
Name:	RS28F version on axis.gif
Name:	rs28f version off axis.gif
                        • #27
                          On axis first.
                          The directivity of the 2 drivers are probably similar too for great power response!**
                          Guess xmax's age.
                          • #28
                            NE225W-4 and RS28F
                            • #29
                              RS 28 W/ WG of course. What mic did you use to measure?*
                              Guess xmax's age.
                              • #30
                                ecm8000
