Need wiring diagram to wire five 8ohm speakers
  • Need wiring diagram to wire five 8ohm speakers
    Need wiring diagram to wire five 8ohm speakers prefer I end up with 4ohm or 8ohm, I already know if I were wiring 6 drivers I could end up at 5.3 ohm , but bassbox is no help trying to figure out wiring 5 drivers , hope this is possible to do. ?
    With 5 drivers you will either end up with a 1.6 Ohm load when wired in Parallel, or a 40 Ohm load when wired in series.
    Parallel is basically just tying all the negative speaker terminals together and connecting to the amp (-), and all the positive speaker terminals to the amp (+). It's likely too low of a load for almost any amp... and 1.6 Ohms isn't really a true figure, it will likely be lower than that in reality -- probably closer to 1.2-1.3 Ohms as a rough guess.
    Series will have too much resistance, that won't work at all, you won't hear the music much over a whisper....
    Odd numbers of drivers are a problem unless they are manufactured on purpose to be used in odd multiples with appropriate voice coil ohm figures.
    TomZ
      By the way, if you have Bass Box Pro, you can see a wiring diagram for 5 drivers or any amount really... go to "Driver" tab, then go to "Configuration" and type in the number of drivers you want, and it will show you the wiring config below.
      If you then go and plot the graph for 'Impedance' and go to the "Parameters" tab right next to it, it shows the results of your chosen wiring configuration in the "Net" column to the right. I did this by only adding the driver Ohm figure as 8 Ohms for Z and 6 ohms for Re, a guess, but probably close enough to show the expected results.
      TomZ
        Originally posted by sdep777 View Post
        this is possible to do ?
        It is not. That's why you don't see an odd number of drivers being used, other than nine drivers, which can be wired to end up with the same impedance as one.
        www.billfitzmaurice.com
          You would be better off using just using four of the five 8 ohm woofers.¬* Two pairs - each wired in parallel, then wire the two pairs in series. That will give you a standard 8 ohm load.
            "It is not. That's why you don't see an odd number of drivers being used, other than nine drivers, which can be wired to end up with the same impedance as one."
            how is that done, need diagram
              ...how is that done, need diagram
                Thank You , wish I could do that with 5 drivers !
                  If ONLY they were 32 ohm drivers ( or at least 20 ohms )
                    I would like to see the same type diagram for 4 drivers 6 drivers 8 drivers etc etc , will look around for some. Thanks again that was a big help
                      It might be faster to learn Ohms Law
                      https://cie-wc.edu/Series_Parallel_9_14.pdf
                      https://www.audioholics.com/loudspea...nection-basics
                      What the 9 speaker scheme shows is an example of a N x N Matrix, that maintained the same resistive/impedance value as an individual element ( where N = 3. A 2 x 2 matrix for 4 speakers, a 1 x 1 for 2 speakers. ) Carry that out to N = 4 for 16 speakers, N = 5 for 25...
                      This is of course just one example of a Matrix series, that can all be simplified with Ohms Law on Resistance.
                        http://www.colomar.com/Shavano/spkr_wiring.html
                          Seems like you¬* could wire 4 in series parallel, that being 8 ohms than parallel the 5th driver to it for 4 ohm total?¬*
                          The group being 8 ohms and the single driver being 8 ohm it seems like everybody would get the same¬*
                          power.
                          Guess xmax's age.
                            The group of four would get half the power, as would the 5th, but only until the 5th was blown.
                              you cd do an isobaric with 10.. bit expensive tho. Sent from my SM-G950F using Tapatalk
