High Pass Filter Circuit....???
  • High Pass Filter Circuit....???
    I believe that the high pass filter section for the tweeter section is a 12dB filter with a crossover freq of 6400Hz. Can someone explain to me what function does the C4 capacitor and R1 resistor parallel circuit serves in the tweeter section?
    Looks like a high pass shelf, to raise the level of higher frequencies. The resistor attenuates at lower frequencies, but the cap cuts in to reduce the attenuation. Maybe the tweeter droops a bit towards the high end.
    Francis
      Realistic Mach 2... old school!
      The parallel RC is a shaping filter. It will reduce output below the critical frequency where the cap opens up and you end up with a series resistor. Above that frequency the cap effectively shorts the resistor out.
      Wogg Music
      Published projects: PPA100 Bass Guitar Amp, ISO El-Cheapo Sub, Indy 8 2.1 powered sub, MicroSat
        It's a contour network.
        https://www.diyaudioandvideo.com/Cal...rNetwork/Help/
        www.billfitzmaurice.com
          In a sim (which you can run yourself), using an "8 ohm" tweeter (w/flat Z-curve - like a planar), it effectively attenuates the tweeter an additional -2dB IN IT'S PASSBAND (which is roughly the topmost octave) with little change to the Fc (and below). (In my moc sim, I can actually get the same x-fer fn by just using the 2 ohm series resistor, w/OUT the cap.)
