Anyone still need CNC cutting?
  • djnagle
    Hi Nik. I tried to PM you but your inbox is full.
    Hi Nik. I just ordered a pair of drivers from Europe and they need to be in 2.8 cu ft cabs. I am thinking about some kind of round sided cabs. Are you taking orders? Dennis from Albuquerque, New Mexico.
  • Pete Schumacher
    Hey Nik, I'm running Aspire on my computer and can generate some interesting surfaces that Aspire can turn into a 3D cut file. Can you do 1.5" thick baffles?
Name:	amt waveguide baffle for 8bg51.jpg
  • STIchris722
    Originally posted by dlneubec View Post
    Nik, Can you do small aluminum parts? If not, does anyone know someone who can?
    I;m talking around 3/4" thick by 2" x 1.5" or so with a v-notch cut across the 3/4" thickness, centered along the 2" length and a 5/16" or so hole bored though the middle of the 2"x1.5" side. Depending on price, might need maybe 25-50 pieces (not for speakers, btw).
    I can't speak for Nik, but I do know machining. Batch work is very cheap and aluminum machines quickly depending on the grade so machine time is less although price is higher than steel. Find a local fab shop or machine shop and get a quote. You are talking about bar stock, cut, faced, notched, and drilled/reamed. Set up a jig and go. Probably could use a Bridgeport with a Prototrak would be faster with less waste than a CNC. Just my thoughts and experience.
  • dlneubec
  • cap
    can you cut corian? its as easy as wood !or MDF
  • Mike220
    I have found so far with my cnc machine i make ups and fedex alot of money.
  • nikbrewer
    What do you think shipping to MA would run? I expect it would weigh around 150# max. Securely packaging a large flat pack like that would be time consuming though.
    I'll consult with my local people but might as well get some data points.
    that's a lot of weight.. would probally go in several packages. Packing is not the hard spot but I would factor in at least $100 in shipping
  • civit
    Originally posted by nikbrewer View Post
    1st. If you have a local Guy, I suggest you use him as shipping is always the killer.
    Just looking at the plans, I would charge about 100$, plus material and shipping. I base my stuff on simple $50 a hour, so that covers programming, machine time, and drive time to get the material ( BB Ply is not stocked a HD< so I have to make a special trip to a lumber yard)
  • nikbrewer
    Hey Nik - I have a few projects going and getting a flat pack made would be a great help. What would you typically quote for a design like this:
    https://imgur.com/a/xrLbYHH
    Basically it's 1 1/2 sheets of mdf or baltic birch with rabbeted edges. I can do all the cad and layout. Shipping to 02143 in sunny Massachusetts.
    I found a guy at a local maker space which has a big CNC but you seem well set up for speakers.
    PS your private messages seem to be overloaded.
  • badman
    I can speak to Nik's quality and fair pricing. He did great work for me, quite a few years back.
  • civit
  • nikbrewer
    In in Oklahoma city, but I used to ship out stuff everywhere. If you search my user name, you can see stuff I did.
  • guitar maestro
    What is your location?
  • nikbrewer
    started a topic Anyone still need CNC cutting?
    I have not been on the site in years (having twins will do that sometimes). I have still worked with a few past customers to keep cutting stuff for home audio.
    My car audio business has started to slow down, and I have made some changes to my CNC router that makes it better suited for the home audio projects. I have added vacuum hold down and better dust collect which helps keep the precision customers want.
    So, is there still a need to custom build enclosures? Build custom flat packs?
    I used to do a lot of veneer work back in the day as well.
