Midwest Audio Fest
See more
See less
CSS drivers, now available at PE!
  • #31
    Originally posted by Krillin View Post
    The return of the SDX7 Woofer would be nice. 11.1mm xmax (one way). And a dedicated mid to match would be sweet.
    This is a pretty sweet driver and so is the VWR126X. Of the two of these, the VWR126X is the more likely to return. The channels are still open for the SDX7, but we'd have to see a lot more interest in this type of driver before we could pursue it.
    Dan
    _____________________________
    Tall Boys
    NRNP Computer Sub
    The Boxers
    The Hurricanes
    The Baronettes
    Conneccentric
    UX3
    • #32
      The SDX7 was a driver that was available, and then just not. Seems it was only available for a very short bit.
      • #33
        Originally posted by DanP View Post
        The SDX10 is actually relatively efficient compared to many 10" subwoofers, so it will do better than most with a smaller amp. It does great in 1 cu ft sealed or 2 cu ft bass reflex. If you ever want more out of it down the road, you could bump up the amp power.
        The 2TD makes a great center channel and was designed with this application in mind. There are inherent issues with a 7" MTM on its side, but these are all but eliminated by a low 1600Hz crossover frequency. The tonal balance is similar to the 1TD, so those can be used as mains with the 2TD for the center or you can stick with 2TDs for the mains for higher output capability.
        Dan
        Thanks for the feedback Dan. I am looking forward to the 2TD "Plans and Measurements" being published.
        The Madeleine
        The Roxster
        Swopes 5.0
        Acoustic Panels
        Living Room Make Over
        • #34
          They are forthcoming along with everything else! Progress is slow but steady...
          Dan
          Tall Boys
          NRNP Computer Sub
          The Boxers
          The Hurricanes
          The Baronettes
          Conneccentric
          UX3
          • #35
            The supplier that makes these does excellent work, but their minimum order quantities are quite high. I think Bob got an introductory order quantity, then couldn't restock at the standard MOQ, so once he sold out, that was it. We would need to see quite a bit of demand for these to justify the high MOQ at this point, but it is a really cool driver...
            Dan
            Tall Boys
            NRNP Computer Sub
            The Boxers
            The Hurricanes
            The Baronettes
            Conneccentric
            UX3
            • #36
              IIRC, it was pretty much similar to the AA 6.5" in both build and parameters, but with a better cone. That one also was very short lived.
              • #37
                I have a minor beef with small woofers that use phase plugs. In some specific applications where the enclosure size needs to be minimized, the phase plug provides an air leakage path through the motor which is just enough that when the driver builds up high pressure in a small box, the leakage around the phase plug can produce an audible chuffing. It's not typical to hear it from the Reference Series woofers because most applications place them in reasonably large enclosures to take advantage of their bass capability, which is one of their key selling points. But if you are thinking of taking a long-excursion driver like the SDX7 and putting it in a small box with a couple of passive radiators, you will likely be rewarded with chuffing. This is why it is not typical to use a phase plug instead of a dust cap on a subwoofer.
                If the SDX7 ever returns, it should have a dust cap, and not a phase plug.
                Technology in the service of art, for the life of the music.
                • #38
                  This is on the table, but not in the forefront right now. ...
                  Dan
                  What about the RT2? I use 3 of these in LCR and love them, a lot. Was there a technical reason / flaw this has disappeared? I didn't even know things had changed hands until few minutes ago. Went looking to see what CSS had been doing and found new ownership, site, inventory and no RT2 :(
                  Here's some officially provided data I captured when I originally gathered supplies before the build.
                  Click image for larger version  Name:	CSS-RT2.png Views:	1 Size:	35.6 KB ID:	1384941 Click image for larger version  Name:	CSS-RT2-2.png Views:	1 Size:	338.2 KB ID:	1384951 Click image for larger version  Name:	CSS-RT2-3.png Views:	1 Size:	173.9 KB ID:	1384952
                  Click image for larger version  Name:	CSS-RT2-TS.png Views:	1 Size:	132.2 KB ID:	1384942Click image for larger version  Name:	CSS-RT2-FR.png Views:	1 Size:	154.1 KB ID:	1384950
                  Feel free to rip my assumptions apart when wrong, or fix if close.
                  Passive Radiators:
                  All PR(s) Vd must at-least double all woofer(s) Vd. Calc = Sd x Xmax to get Vd for all PR(s) and all woofer(s). If all PR(s) Vd at-least double all woofer(s) Vd they'll work.
                  For woofer(s) with large Xmax vs Sd, all PR(s) with Xmax at-least double all woofer(s) Xmax will work.
                  A PR max weight is said to be its Mms x3
                  PR Systems - tight focus with key parameters.
                  PR Speaker Design - thorough coverage.
                  • #39
                    Agreed. It appears that the SDX7 was an attempt to combine a great midrange and a great small subwoofer into one driver, but unfortunately, many of the design choices that make a driver great in one regard or another are contradictory. In the end, you still end up with a driver full of compromises. It's too bad too, because I actually really like that copper phase plug.
                    Dan
                    Tall Boys
                    NRNP Computer Sub
                    The Boxers
                    The Hurricanes
                    The Baronettes
                    Conneccentric
                    UX3
                    • #40
                      We have no plans to continue the RT2. It was a good driver, but Kerry and I felt it offered nothing unique in it's price range. The LD22F has the capability to cross lower with minimal distortion than any other small (<25mm) dome we know of. The LDW7, as Pete mentioned, is on par with Scan Revelators at 70% the price. The SDX10 and SDX12 have the highest output/distortion ratio of any subs in their price range. Even the APR10 and 12 have the best price/performance ratio of any passive radiators we know of. Our goal is to produce only products that outperform most if not all other drivers in some highly desired metric(s). The RT2 was solid, but did not fall into this category in our opinion.
                      Dan
                      Tall Boys
                      NRNP Computer Sub
                      The Boxers
                      The Hurricanes
                      The Baronettes
                      Conneccentric
                      UX3
                      • #41
                        ... . Our goal is to produce only products that outperform most if not all other drivers in some highly desired metric(s). The RT2 was solid, but did not fall into this category in our opinion.
                        Dan
                        Appreciate the update, and looking forward to see how things pan out. The stated goal is compelling and ambitious. All the best with it!
                        At the time, near 4 years now, RT2 was an exquisite selection and match for me in parallel Esoteric LCR and certainly no regrets. They're incredible in function and reproduction, have been hammered on a regular basis while going strong as ever, and they can really crank.
                        I've never heard them do anything except fill the space at unbelievable volume with perfection. With ever growing progress the current generations in the same league and higher must be really remarkable.
                        Passive Radiators:
                        • #42
                          Dan
                          Any plans to bring back the Planar1 and Planar2?
                          • #43
                            Honestly Pete, I know very little about these drivers. There were none in inventory when we took over and I've never heard them. I don't remember a lot of conversation about them when they were available either. Based on a quick google search, it seems like they weren't very prevalent, but those who used them loved them. We'll have to look into this further. What were your impressions of them?
                            Dan
                            Tall Boys
                            NRNP Computer Sub
                            The Boxers
                            The Hurricanes
                            The Baronettes
                            Conneccentric
                            UX3
                            • #44
                              i think an all CSS threeway is in order !
                              donc
                              • #45
                                Dan
                                That driver (the SDX7 Woofer) is a BEAUTIFUL beast
                                Sausage With Meat Sause, Please
