Soundeasy Digital Filter Help, please.
  • Soundeasy Digital Filter Help, please.
    Perhaps I am being dense, but…
    I am trying to emulate a two-way analog active crossover in SoundEasy. For stereo playback, I need 2 in 4 out, but can only get 1 in 2 out.
    In other words, for example, I can get the left channel (CD player left output to soundcard left input) split into woofer and tweeter outputs to feed the amps and drivers but cannot get the right channel (CD player right output to soundcard right input) mapped to any soundcard outputs. Of course, I can swap the left/ right inputs, but then the situation is the same, only reversed.
    One thing I noticed that’s odd is that my Digital Filter dialog box only has “stereo” selections (2x2, 2x3, etc) while the manual shows both stereo and mono options.
    The Soundeasy manual strongly implies that DF stereo playback should be possible, but really doesn't speak to this as far as I can tell.
    Anybody have suggestions? Google has failed me.
    Thanks
    Have you checked with the SE user group at Yahoo? Seems like there must be a simple solution. I don't use the emulator so don't have much else to offer.
    ~Brandon
    Soma Sonus
    DriverVault
      JRT
      Thanks for the input.
      I'm using a SE V22 and a Delta410 (PCI) and haven't been able to determine which driver type it uses, but I thing it's MME? Also, I'm not sure how to determine which "environment" I'm in despite some googling.
      I considered the Ultimate EQ option, but I'm trying to fine tune an active analog design, which I will put on a PCB in a custom amp/ XO unit. If I understand correctly (always up for dispute!) Ultimate EQ won't allow me to do this.
      I know that there's a decent SE user base on here and hope one of you fine folks has been through this and can help. dlr
      If I don't get an answer/ figure it out here within the next couple of days, I will post a request to the SE board later. Soon, I will be away for a couple weeks, so I didn't want to start what amounts to a formal help request on the user group with bohdan until I have time to pursue the issue in "real time"
      For obvious reasons, I'd love to listen to it before committing to buying parts and populating the SMD PCB. I realize the entire project is somewhat anachronistic, but I'm doing it as an exercise in design and PCB layout just for fun.
        Hi Zach,
        SE V22 came out in two versions. It is possible, you have V22 WASAPI version, while you need MME version for your card. Also, for Delta410 card you need Windows 7(maximum) or WinXP. I am not even sure, that there is Delta410 driver for Windows 7 - you'll need to check this. Please contact me directly with an email for MME version.
        Best Regards,
        Bohdan
          Originally posted by bohdan View Post
          Hi Zach,
          Best Regards,
          Bohdan
          Thanks
          I am using Windows 7, for which there is no official driver that I can find. So far, the latest Vista driver has been working for me. Here's hoping it continues to as I explore new (to me) features.
          I will contact you soon for the MME
          Thanks again.
            SE V22 came out in two versions. It is possible, you have V22 WASAPI version, while you need MME version for your card. Also, for Delta410 card you need Windows 7(maximum) or WinXP. I am not even sure, that there is Delta410 driver for Windows 7 - you'll need to check this. Please contact me directly with an email for MME version.n
            I'm still using UE5 Lite with a Delta 410 in Windows 7. Like Zach, I think I had to use the Vista drivers.
            dlr
            Dave's Speaker Pages
              With some clarification from Bohdan about what I should be seeing and after digging around in the Windows Sound settings some more, it seems that I found the problem.
              Under Control Panel/ Hardware and Sound/ Sound/ Playback/ Multichannel (Maudio Delta 410)/ Properties/ Advanced, the soundcard was set to two channel, and needed to be switched to 10 channel.
              I may not get a chance to actually hook up/ listen for a couple of weeks, but the Delta 410 Control Panel now shows activity on the VU meter for channels 3/4 while the DF is running, so I think it's all sorted out.
              Thanks to all who gave input!
                Zach, thank you for posting this here. I had the same problem; your post provided the information I needed to fix it.
                  Good deal.
                  Soundeasy is great and powerful (It's from Oz too... Coincidence?) but can be frustrating at times.
                    MiniDSP 2x4 solves all your problems for $95. Check it out.
                      MiniDSP can take my analog circuit design and simulate its exact filter transfer function as a digital filter with the click of a button?
