pa sub build
  • pa sub build
    hi I was going to build an EAW sb180zp subwoofer box and was wondering if any of these subs would work with it selenium 18sws800, eminence sigma pro-18a-2, or the eminence omega pro-18a?
    I believe the driver EAW use in that box is one of the 18" models from 18Sound. If you want to substitute a different driver you'll need to recalculate the ports, and come up with your own processor settings. In essence, designing your own enclosure with the same external dimensions as the EAW.
      It would be best if you could run some sims. Then you would have a better picture of what to expect. To my eyes, X-max seems a little low on all of the mentioned drivers. I would expect that to be in the 9-10mm range on mid-priced pro drivers.
