RFL-3way. Work in progress
  • RFL-3way. Work in progress
    Hi all,
    http://techtalk.parts-express.com/fo...-classic-3-way
    A short status report on the progress for the system:
    The mid/tw unit is finished and the 2500 XO-point is validated through measurements today (See attached pictures ). Five components is quite OK, I think.
    The woofer unit is finishing in the workshop. Will post pictures when ready in a few days.
    Regards//lasse
Name:	Mid Tw unit 2018-10-30.JPG
ID:	1392123Click image for larger version
Name:	Mid tw unit Design 2018-10-31.JPG
    Perry Mason talking to his dentist:
    By the way, hete is a Picture of the woofer units taking shape…
    regards//lasse
Name:	Woofer unit in progress.jpg
      Wow - another Speaker Workshop user. I thought we were all dead lol.
      What acoustic slopes are you targeting. If "traditional" LR - you're getting a lot of destructive phase - also xo point not -6dB (if you are intending LR slopes). Attached is an example of my 3 ways
        Hi, Dave,
        yes I have notice the phase issue bit when the measurements were ok, I decided to try the prel XO. Perhaps go up to 3rd order on the tweeter....
        The target is LR2
        How does your system measure??
        regards// lasse
          G'day Lasse,
          Attached are sims and actual measurements. The W/M crossover doesn't show the null (polarity reversal) due to limited ability to measure at a low enough gate. I hope to take some better outside measurements.
          The crossover has evolved since then (you'll notice the M/T crossover was lower @ 2KHz). The tweeter had issues here and it was preferable to play the mid higher than the tweeter lower.
          The slope / dip is intentional as I was struggling to get the speaker sounding right on certain recordings. I came to the conclusion the mix was very forward as well as tweeter issues. A combination of factors. Overall the speaker sounds happier with a 3KHz XO. I might ease this back to 2.5KHz and make flatter. A downward slope however (although not accurate) sounds better to me for the music I listen to. And that is all that matters.
          the key takeaway is there is accuracy from my sim as well as measurement - so I can make changes with confidence
Name:	Suboptimal xo - Overall in phase sim vs actual.png
ID:	1392269Click image for larger version
Name:	Suboptimal xo - Overall out of phase sim vs actual.png
            Hi Dave,
            That really seems to be a successfull design. I am really happy for you, getting that close correlation between sims and measurements. Personally, I would be hesitant to make the high end go up like that, but what you sate is quite true: All that matters is that you think that the sound is right.
            But this raises another thought for me and that is why ”bad phase tracking” really is that bad as it is stated in the litterature and on this board.
            If the contributions from two drivers in the overlap region result in a flat SPL, disregarding their phases in the region, then what is the problem?
            I think that this should be a topic for a separate thread on this board.
            Will be back in this thread with pictures on the completed woofer-units for the RFL-3way.
            Best regards//lasse
              ...and here is a Picture of the finished, but not yet stuffed wooferunits…
              regards//lasse
Name:	Basar RFL-3way mindre.jpg
                Nice work. Are you using metal drivers? If so, mine is also an all metal 3 way. Here's a photo of my measurement / test mule (pre roundovers and driver install). No bracing. Just stuffing and volume (Q tuning) experiments at this stage
