Do you need to "Break In" speakers?
  • Do you need to "Break In" speakers?
    Hey guys, thought this would be the best forum to raise this question, do you need to break (or burn) in speakers, amp boards or componentry? I've read that yes you should and even seen comments like "nah don't need to with this new tech"
    So if the response is yes, is there a nominal amount of hours required before.winding those beats up to the max?
    Driver's suspensions will relax a bit with use, some more than others, so you might see a slight change in measured parameters. However, usually the shift is something that will not require a different box alignment due to what shifts and compensates by other parameters.
    Capacitors are said to 'form' with use, but to my knowledge, this also causes minimal concern. Some chipsets, transistors, and tubes require a certain temperature of operation to sound their best according to reviews.
    Honestly- none of these durational changes and concerns are likely to be rife with issues when they occur or when they don't.
      If you're designing a cab and want to be sure that the driver is fully broken in when you build and test the prototype you have to break in the driver. If you want a cab to perform the way it should from the get go you should break in the driver. If you're content to let nature take its course, as the driver will eventually break in from use. don't bother. I recommend breaking drivers in not just for reasons 1 and 2 but also to weed out a potentially bad driver.
      www.billfitzmaurice.com
        Thanks guys, i'll take it easy on them for a while although it will be hard once i get my latest project working....
          It's not like a car engine... the best way to break them in is to not take it easy on them!
          Wogg Music
          Published projects: PPA100 Bass Guitar Amp, ISO El-Cheapo Sub, Indy 8 2.1 powered sub, MicroSat
            I strike a balance between a babying and beating break-in
              Exactly like a car engine. Light loads and low RPMs on a fresh engine is the receipe for poor ring seal.
              Craig
                Definitely true, too low of rpm on break in is also a good way to wipe out a new flat tappet cam!
                Projects:
                Breezy Monitors: http://techtalk.parts-express.com/fo...reezy-monitors
                transcenD: http://techtalk.parts-express.com/fo...5035-transcend
                Summits: http://techtalk.parts-express.com/sh...75-The-Summits
                References: http://techtalk.parts-express.com/sh...-My-References
                Vintage Style 2-way: http://techtalk.parts-express.com/sh...-vintage-2-way
                  I take it easy with the voltage, giving them enough to take them close to xmax, which with a low enough frequency sine wave and the driver unmounted isn't that much. What matters is flexing the suspension, not heating up the voice coil.
                    Interesting, we just did an engine replacement a couple months ago. I got a wide range of break in opinions, ultimately the tactic was to vary RPM as much as reasonable and don't go stomping the gas, just drive normally. A few paddle down shifts every now and then is what I did, but it's the wife's car so I'm sure she just drive it like she always did.
                    Wogg Music
                      Exactly how I do it too. My intention was that if you're already in listening mode anyway, you don't have to be shy on the volume knob. Let them do their thing, they'll loosen up.
                      Wogg Music
