Buchardt s400 inspired bookshelves
  • #16
    I buy it, if it places the woofer acoustically closer to the listening position.
    • #17
      WG 300 on EBay...
      https://rover.ebay.com/rover/0/0/0?m...2F152938024595
      • #18
        Thanks looks very similar but not identical to http://www.allaudioexpo.com/nav/details.asp?itemid=306 . Maybe I should order both and try to create a cad model for future reference.
        Is there any further information on the Jeff Bagby revolution?
        • #19
          That is a threaded mount horn for compression drivers.
          • #20
            True but it's much cheaper and I think you can break off the threads and create a modifier piece to interface with a tweeter.
            Probably much easier to get the WG 300 (it says it has a 38mm cutout), but the compatible driver is 30mm ~ 1 - 1/8"
            • #21
              I ordered the WG 300 waveguide. I'm trying to pair it up with a tweeter.
              I'm thinking the Dayton Audio RST28F-4 could be a good option.
              The WG300 waveguide has an outer diameter of 168mm
              The SB17NRXC35-4 woofer has an outer diameter of 159mm; pretty annoying since that leaves a 4.5mm visual difference in the diameter from the edge of the baffle.
              • #22
                That looks an awful lot like the horn zaph milled down here:
                http://www.zaphaudio.com/Waveguidetmm.html
                My recollection is that this also worked well with:
                https://www.parts-express.com/peerle...eter--264-1014
                The face plate comes off that tweeter very easily with a little heat.
                Can't remember who used the mcm and vifa together. Somebody around here does, surely.
                • #23
                  Did I miss something? The Buchardt S400 uses an SB15NBAC30 - NOT an SB17. (Or at least its something that SB made for them. The pictures show a 145mm driver marking.) If you use an SB15, the Wavecor WG 148 R is almost a perfect match sizewise - 150 vs.148 mm.
                  -Bob
                  The PEDS 2.1 mini system
                  My A7 Project - another small desktop speaker
                  The B3 Hybrid Dipole - thread incomplete and outdated
                  • #24
                    Their site says the box is 180mm wide. The woofers are almost to the edge - and they do say it's a 6" aluminum woofer. The SB17 measures 171mm in diameter.
                    I'm also guessing the elaborate crossover they show is not what's actually in the S400.
                    • #25
                      Serves me right - I was looking at the S300. I'm still skeptical there's that many crossover parts in the S300.
                      ** I stand corrected. http://highfidelity.pl/@main-741&lang=en
                      • #26
                        Originally posted by civit View Post
                        Revolutions use the sb15 satori.
                        https://m.imgur.com/a/Uw9oHbC
                        I believe there are 2 versions of this kit. One uses the SB ceramic 5", and the other uses the smaller Satori in about half the volume. They use the same SB Be tweeter.
                        • #27
                          On second thought, it does look like an SB17. My bad. I was thinking there was a round over on the front baffle, but it doesn't look like it.
                          -Bob
                          • #28
                            FWIW, the S400 description says 3/4" tweeter, I'd bet it is the SB19ST. I imagine that small tweeter worked pretty well.
                            ~Brandon 8O
                            Please donate to my Waveguides for CNC and 3D Printing Project!!
                            Please donate to my Monster Box Construction Methods Project!!
                            DriverVault
                            Soma Sonus
                            • #29
                              Or you can choose the less expensive ($511 less expensive) SB29SDAC instead of the SB29BAC Be tweeter. So there's a total of 4 possible versions. I don't know if there any crossover changes when you make the tweeter selection or if the SB29SDAC and SB29BAC are swappable w/o any changes.
                              "Everything is nothing without a high sound quality." (Sure Electronics)
                              • #30
                                Supposedly the 29 was a drop-in for the Be, according to one of the articles/pages. I'm assuming the xover is different from Be to Mini though.
