Just a little update from my project:
I semi finished the first cabinet to be able to get proper measurements for the crossover development.
The 2 degree angle was also neglected.
I ended up having to use 16mm MDF as my local supplier didn't have any in stock and ordering it would have been substantially more expensive. The S400's original outer dimensions were kept, so i ended up with a slightly larger internal volume. The cabinet is fully treated with 3mm butyl aluminum sheets and 3mm self adhesive insulation foam(Dynaliner).
Attached is the measured frequency response with the test crossover. I'll get someone to check the impedance and phase response and if that's okay then i'll go ahead and order the XO components.
The woofer runs on a 4th order and the tweeter on a 3rd order with and L-pad to level it down to the woofer.
I'll post final pictures once completed.
