"Tube Amp" Headphone Amp
  • #16
    Yeah, my amp and preamp are covered, the ST35 has a perf metal cover so you can see inside a bit.
    • #17
      Originally posted by guitar maestro View Post
      BF, if would please enlighten me: What constitutes a good SS amp?
      IMO what constitutes a good amp is transparency, as in the old saying 'a straight wire with gain'. Doesn't matter if it's tube, SS, Class A, A/B, D or whatever. If you're a devout minimalist and believe the fewer parts the better you may think that nothing else approaches the supposed sonic purity of a 3 watt SET into a single driver. I lean more towards Duke Ellington's philosophy, that if it sounds good it is good.
      www.billfitzmaurice.com
      • #18
        My pet theory as to why transistor amps used to be inferior to tube amps has to do with crossover distortion. Early class AB transistor amps did not generally do a good job controlling output stage bias under varying conditions. As time went on, clever designers developed schemes to better control bias, but the damage was done, and tube amps developed a mystique. The ultimate has to be class A, with no crossover distortion, but practically speaking modern class AB transistor amps are fine for anything except perhaps horn drive, where you're only using maybe 10mW of average power.
        Francis
        • #19
          Can you give your definition of "transparency" in terms of quantitative specifications pertinent to amplifiers?
