Midwest Audio Fest
See more
See less
Max / Recommended added weight for a passive radiator?
  • Max / Recommended added weight for a passive radiator?
    Hi,
    I'm thinking about using the PE DSA315-PR in a new build.
    It has 142.6 G mms, but I seem to remember that there is a maximum of added weight or "bad things happen".
    Does anyone know what that ratio (stock G to added G) is?
    Dayton Audio DSA315-PR 12" Designer Series Aluminum Cone Passive Radiator
    Tangband W6-sub
    It really depends on how strong the suspension is. Too much weight and the suspension will bend since it can't hold the cone straight anymore, creating some non-linear behaviour. Many manufacturers will specify a max weight, I'm sure Dayton could provide you with some guideline if you asked them.
      Yep, but they are closed today. Good for them. Everyone needs some downtime.
      Tangband W6-sub
        Don,
        I remember reading something about PE's suggestion on adding weight to their PR's...
        the maximum recommended weight added should be no more than existing mass plus 60%
        per what Matt P mentioned in the Q and A section on one of the designer series PR pages as mentioned in this post:
        http://techtalk.parts-express.com/fo...52#post1285852
        Looks to be about 228 grams total, or add no more than about 85 grams,
        if you follow that rule of thumb.
        I've got a few of the 10" versions of that aluminum PR coming in a few days, I'm looking forward to comparing it to the paper version in appearance. Looks like a sexy drone cone!
        TomZ
          Thanks Tom - I forgot that you used that recon ebony on some of those little subs. I just got a sheet of.
          I'll model the box using a 60% limit. May have to bump up to a larger PR....
          Jeff B recently posted a long thread about the advantages of a PR over a port, and that, combined with
          the great pricing on the new PE DSA PRs has got me going for more PRs, less ports.
          Plus, I just realized that a large PR gives you a convenient access hole if you need to get to the interior after glueup.
          Tangband W6-sub
            I've made up this PR chart (it's formatted for a plain text editor - so it might look a bit funky w/out some work). The biggest unknown (for most PRs) is added mass limit !
            PRs @ PE Adding MASS > +^ -v (Xmech)
            Peerless: Vas/cf Qms Fs Sd/sc Xmax OD (Sd*X?)
            $ 10 264-1060 830878 3.5" 0.10 10.0 29 50.2 ?5<3? 4.9 ?3oo? 40?-5o
            830880 5.2" 0.37 10.0 23 87 6.0
            Dayton: {DS prs cheaper than DSAs} 2/5 (20) 9/27
            $ 8 290-205 ND65-PR 2.5" 0.02 2.69 73.0 15.6 5.0 2.6 1x 4.3g disk
            $ 10 290-209 ND90-PR 3.5" 0.05 6.15 53.8 31.2 9? 4.1 2x 7.3g disks
            $.10+295-491 DS90-PR 3 " 0.124 5.9 42.4 31.2 4.0 3.7 12o ? ?
            $ 11-295-542 DSA90-PR 3 " 0.124 5.72 43.7 31.2 4.0 3.7 12o ? ?
            $.11+295-493 DS115-PR 4 " 0.33 3.66 29.3 54.1 6.0 4.6 32o ? ?
            $ 12 290-213 ND105-PR 4 " 0.09 5.93 51.5 51.5 6? 4.2 2x 21.8g disks
            $.12+295-495 DS135-PR 5 " 0.43 3.93 27.7 75.4 8.0 5.4 60o ? ?
            $ 12-295-544 DSA115-PR 4 " 0.33 3.48 30.9 54.1 6.0 4.6 32o (wt.limit?)
            $ 13-295-546 DSA135-PR 5 " 0.43 3.7 27.9 75.4 8.0 5.4 60o ? ?
            $.14 295-498 DS175-PR 6.5" 0.61 1.8??_30.2_ 128.7 8.0 7.0 103o 60?
            $ 14 290-217 ND140-PR 5.2" 0.30 4.02 44.2 86.6 9.0 5.5 2x 18.5g disks
            $_15 295-548_DSA175-PR 6.5" 0.95 4.30 26.8 128.7 8.0 7.0 103o ? ?
            $.18 295-492sdDS215-PR 8 " 1.40 7.34 23.3 194 9.0 8.6 175o 75?
            $ 20 295-549 DSA215-PR 8 " 1.30 7.66 25.6 211.2 11.0 8.5 232o ? ?
            $.27 295-494sdDS270-PR 10" 3.90 3.98 19.5 340 10.0 10.7 340o ?90(19oWolf)
            $ 28 295-552 DSA270-PR 10" 3.74 5.26 21.9 353 11.0 10.7 388o ? ?
            $.34 295-496sdDS315-PR 12" 5.20 4.27 17 480 10.0 12.4 480o 100?
            $_36 295-554_DSA315-PR_12" 6.74 6.23 17.5 480 13.0 12.4 624o ? ?
            $ 75 295-500 RSS265-PR 10" 2.11 4.92 19.6 356.3 24 10.6 8.5k! +5 75g disk
            $ 90 295-502 RSS315-PR 12" 2.79 4.79 21 506.7 26 12.4 13.2k +6 disks
            $120 295-504 RSS390-PR 15" _7.51_ 4.01 _18.2_ 829.6 30 15.3 24.9k +7 disks
            $140 295-506 RSS460-PR 18" 15.9 5.03 14.7 1164 34 18.2 40ooo +8 disks
            (wish I could store these in WinISD somehow?)
              Don, would you happen to remember where you saw that thread Jeff posted regarding PR's? I did a search and couldn't come up with it.
              TomZ
                Don,
                TomZ
                What may be ADDED is 160% of Mms, not 60%. Even this ROT does not apply to all PR's as there are a lot of variables at play.
                  TomZ
                  Over on Facebook - "DIY Loudspeaker Pad" - Javad, Jeff B and another guy are admins. Love to have you there.
                  It was a great writeup on PR use and benefits.
                  Tangband W6-sub
                    Thanks Man! I was pretty sure (age-related-memory bitrot) that you could add over 100%, but in any case, I'll call PE when they reopen and ask them
                    to document their recommendations, or I'll publish it here.
                    Tangband W6-sub
                      Sorry about posting possibly misleading information...
                      This was the info posted on the 6.5" PR as I mentioned above...
                      __________________________________________________ _
                      How much added mass can these handle safely?
                      CPop78 on Mar 4, 2015 BEST ANSWER: I usually recommend no more than about 60% of the Mms of the passive for these.
                      • MattP on Mar 4, 2015
                      • __________________________________________________ __________
                      That info was posted in the Q & A section on this 6.5" PR:
                      https://www.parts-express.com/dayton...iator--295-498
                      That was where I got my 'line of thinking' from... but I think the Reference Series of passives could handle more than 60% of existing mass quite easily.
                      It would be great if PE would supply a 'max added weight at Xmax' spec to their PR's so we know how far we can push them weight-wise.
                      Thanks Don for the info on the PR article... I'll check it out... Obviously I'm still learning!
                      TomZ
                        Thanks Tom - agree that PE needs to specify this. It's a critical aspect of using their product.
                        Tangband W6-sub
                          I think adding a max of 160% is a good rule of thumb. The RSS315-PR for example, has a 300g mms and comes with 6 disks that are 75 g each, which is 150%.
                            I know the old SD PRs used to have it in their spec sheet. The SD215PR is good for 250g, but I don't know if that is max or added.
                              Prize goes to 1100xxxben - looks like 150% or so is max.
                              Gotta recap my phone call to PE today:
                              Guy answers, I explain my question, he says "Well, look at that M5 bolt, you can only add so much weight"
                              I say "But at a certain added weight the response will become non-linear, or the PR will have physical damage in the surround or spider"
                              He says, look at the RSS265 PR - you can add a max of 150% with the included weights.
                              So until I hear differently, I'll model with 150% max added weight.
                              <smile>
                              Tangband W6-sub
