When gluing-up mitered MDF enclosures, don't forget to apply glue to the extreme ends, otherwise you'll have one corner w/o any glue.
Good thing I caught that in time.
Any longer and it would have been a problem because the front and rear baffles are inset and glued into grooves. The glue hadn't set-up so I was able to tap it back apart and squeeze some glue into the joint.
I guess this is a good reason to use the original Elmer's white glue, which has a longer open time than the Titebond stuff.
